Anyone use the second input of your amp?
Discussion in 'Amp Central Station' started by tap4154, Nov 24, 2021.
  1. Maguchi
    Maguchi Tele-Afflicted
    Lalaland
    Yup use 'em both (or 2 out of 4 on Tweeds). Often at the same time, switching between them for different sections of a song, with a different group of effects plugged into each input. Since one of 'em is hotter than the other, I'll use an A/B footswitch to switch to the hotter input for solos too.
  2. JDB2
    JDB2 Tele-Holic
    Arizona
    I always use #2 to help tame my Fender Prosonic
    Maguchi likes this.
  3. Willie Johnson
    Willie Johnson Tele-Afflicted
    Chicagoland
    I do it sometimes with my PRRI when I'm trying to equalize volume with my other Princeton.
    I've noticed that the PRRI's output seems to be buffered when I have a jack in output 2 when I daisy chain in another amp, and gets louder when I unplug it; I thought the -6dB was supposed to be defeated when both inputs were being used.
  4. Ezee
    Ezee TDPRI Member
    PE
    Roland Chorus JC amps are excellent, but known for that hiss. On a whim I plugged in to both the High/Low directly into my Modeler. Lush Stereo and Hiss free. : )
  5. Tim S
    Tim S Tele-Afflicted Gold Supporter
    Upstate NY
    FWIW, from https://robrobinette.com/How_Fender_Input_Jacks_Work.htm
    The Lo inputs are attenuated by slightly more than -6dB to offer less gain and more clean headroom. If you find you prefer the Lo inputs I recommend you try using the Hi inputs and turn down the guitar's volume control. You get pretty much the same outcome but you have control at the guitar but the Low jack's low input impedance can remove some high frequencies from the guitar pickup so the guitar tone is typically a little less bright when compared to the Hi jack.
  6. Twang Deluxe
    Twang Deluxe Tele-Afflicted
    Germany
    I use the second input of my TMDR when I play my Yamaha Reface CP through it. The Rhodes sound is really amazing
  7. peeweepete
    peeweepete Tele-Meister
    Germany
    I exclusively use the second input on my Twin.
  8. tap4154
    tap4154 Doctor of Teleocity Ad Free Member
    Southern California
    That's interesting, because the Tex-Mex pickups are extremely bright. In fact I already pushed all the poles flush with the pickup covers, and put a .1 uf tone cap in it to try to tame it, and it's still pretty bright to my ears if I have the tone pots full open. So maybe for this guitar, using output 2 is perfect, because it also attenuates some of the highs? I guess everyone just has to see what works in their particular situation and tone preference..
  9. Sparky2
    Sparky2 Friend of Leo's
    Harvest, Alabama
    I do, but only when I want to make Input #1 jealous.
    :oops:
    boxocrap and Greggorios like this.
  10. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    About half the time - even with my single coils. To get the same volume level, it requires cranking the amp a little higher, which often sounds good and changes attack/response a tiny bit.
  11. Boreas
    You could, but it often shaves a bunch off the top-end frequencies.
  12. tap4154
    Southern California
    Exactly, that's what I was thinking. It allows you to crank the amp more to achieve the same overall volume, which can improve tone, attack, and allow you to fully use the guitar controls.
    Boreas likes this.
  13. JL_LI
    JL_LI Poster Extraordinaire
    Long Island, NY
    I don't have one. I'm feeling left out. Does the 5 watt mini toggle switch on my Boogie count?
  14. Dismalhead
    Antelope, California
    I use the Low input on my little Supro 1606. IMO it does pretty much the same that you've experienced.
  15. FenderLover
    Minnesota
    Another effect is added loading - the resistive divider on input 2 is only 68K to ground, while input 1 is 1M to ground. You get the -6dB but lower impedance in parallel with your high impedance guitar jack.
    If it works, it works.
    beanluc likes this.
  16. bblumentritt
    bblumentritt Friend of Leo's Gold Supporter
    Austin, Texas
    Yes.
    I use the Fender type 6dB cut sometimes for high output humbuckers, or if I want less volume.
    However, not all amps are created equal. I have a Curt Lancaster amp that the high input in Marshall 800 territory, and the Low input gets you more of a Fender blackface thing.
  17. boxocrap
    boxocrap Tele-Meister
    north delta british columbia canada
    gridlock likes this.
  18. boxocrap
    hmmm...i not knew that even after decades of owning a super reverb..thanks
  19. tap4154
    Southern California
    I don't know if that's how every amp operates, but it's how the old red knob Super 60/112/210 operates.
  20. tiktok
    tiktok Poster Extraordinaire
    Oregon coast
    I use it when I want to use an 18w Marshall circuit as a pedal platform.
