Anyone Use a Weber Rather Than a Distortion Pedal?
Discussion in 'Amp Central Station' started by zimbo, Oct 8, 2013.
  1. zimbo
    zimbo Friend of Leo's
    Rochester, NY
    For playing through a DRRI at home I'm wondering if I could use a Weber to get breakup at lower volume rather than using my Fulltone pedal? Or do you need both together?
  2. old goat
    old goat Tele-Holic
    Donner Lake
    Do you mean weber attenuator (mass or minimass?) Yes--you can get breakup with the weber alone. You may or may not be happy with the attenuated tone. The more you attenuate the worse the tone--works best if you need to quiet the amp down a little at a gig, rather than for using a club amp for home. More wear on the tubes than using the pedal.
  3. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Weber ? Weber what ?
  4. fezz parka
    fezz parka ---------------------------
    Del Floria's Tailor Shop
    Weber will get it smokin':
  5. gpasq
    gpasq Friend of Leo's
    Littleton, CO
    I use one of those as my slide at bbqs. A beer bottle is too unwieldy
  6. Frodebro
    Seattle
    I've clamped my DRRI down with a Hot Plate, but at lower volume levels the are certain things missing that make it easier to just throw an overdrive in front of the amp.
    The speaker isn't working hard, and the Fletcher-Munsen effect also comes into play.
  7. Larry F
    Iowa City, IA
    I don't use one with my Quinn Dumble-type amps, but will with my Ceriatone Trainwreck clone. It's 50w and has no master vol. The breakup occurs around 6 on the volume, which is really loud. I will either use a Zendrive (or maybe a Fuchs Valvejob) or a Weber mass. It is somewhat pleasing, but, for the reasons mentioned above, is missing something. However, I recently bought a Bad Cat Leash (or Unleash?) which is fantastic. It uses a different design. It can be used to attenuate, or boost by up to 100w. Expensive, though, maybe $300-350.
    Knowing what I do now, I would recommend that the OP use a Zendrive type of pedal. There are a lot of things you can do with it that don't necessarily include OD, per se. Maybe OD-ish.
    (Help. I am on a roll using the phrase "per se" and attaching "ish" to words. Can't stop, per se.)
  8. bun malaey
    bun malaey Tele-Afflicted
    Shertz, TX
    I don't use either, gots me a two channel amp, it's revolutionary.. has a clean channel and a overdrive/distortion channel. Modern technology. Who'da thunk.
  9. RubyRae
    RubyRae Friend of Leo's
    Cincinnati
    Bwah!
    Oh Zimbo, this thread is all kinds of funny.
  10. lothar34
    lothar34 Tele-Meister
    Nashville
    Since attenuators only knock the volume down a little (before noticeable tone loss) I wonder if combining an attenuator with an Eminence Reignmaker would work?
  11. CyanideJunkie
    CyanideJunkie Tele-Holic
    Singapore
    I use my Mini Mass in conjunction with my boosts. That way I can hit mega-saturation levels without putting out too much volume and still preserve high-end.
  12. zimbo
    Rochester, NY
    Thanks for the tips. It looks like I could get a Weber Mini Mass fairly cheap but I kind of like the stuff coming from the Zendrive pedal that Larry mentioned. Looks like they have a leg up on Fulltone.
