Anyone use 9's anymore?
Discussion in 'Telecaster Discussion Forum' started by eno55, Apr 13, 2011.
  1. FredJr
    FredJr Tele-Meister
    Prospect, CT
    Jaguars have a 24" scale - seems to me that there you need the larger gauges to prevent the flopsies :lol:
  2. AngryHatter
    AngryHatter Tele-Meister
    Los Angeles
    I have 009s on my Jag as well.
  3. FredJr
    FredJr Tele-Meister
    Prospect, CT
    THAT is way cool :D I never woulda thought that was possible - when I played a Jag I used 11s and then 10s but never 9s - If I had one now I would definitely try it.
    Dang, now I miss my Jaguar :cry: - I had a 1968 with block inlays in the neck. I never shoulda sold it (how many times have we said or heard that :confused:)
  4. jvanhorn
    jvanhorn Tele-Meister
    Clinton, Arkansas
    Me too. Ernie Ball pure nickel. I do make a sllight modification. I throw out the .38 and put on a .40. The .38 just does not have enough bass for my taste. Other than that no problem whatsoever.
  5. banjohabit
    banjohabit Tele-Holic
    virginia
    the touch IS the deal. i play bare-fingered and that probably has a lot to do with the heavier strings sounding better on my axe. it had never occured to me before in the electric context but i also play a WAY heavier set-up on banjo than most guys. LOL!! when they pick mine up i can usually silently mouth their first comment: " how do you PLAY this thing?! UGH!!" of course with that heavy-duty banjo set-up i can peel paint off of walls and run any three guitar pickers out of the room, (if i want to). but i don't set it up that way for the volume, it's for the tone and TOUCH.
  6. Twang Chung
    Twang Chung TDPRI Member
    Santa Barbara, CA
    I have 3 teles. The 72 deluxe is .08 the highway one is .09 and the GC MIM BSB is .10. No real rhyme or reason. Just whatever strikes my fancy at the string racks. I do tend to go with Ernie Ball 90% of the time as they seem to be the cheapest. I spend a ton of cash on guitars then buy the cheapy strings. Lol
  7. birv2
    birv2 Tele-Afflicted
    Charleston, SC
    I also play fingerstyle electric and just switched from 10's to 9's. I would argue that everyone's touch is different, and so is resulting tone. I'm actually getting more oomph since moving to lighter strings. YMMV.
  8. FredDairy
    FredDairy Friend of Leo's
    Chicagoland
    True. That was 1/2 of the issue though. The saddles on a Jaguar will shake themselves loose leading to an unintonated guitar if there is not enough down force on the bridge by the strings. So shimming of the neck was part of the fix but the heavier strings also helped make the bridge slightly more stable as well.
  9. Wrong-Note Rod
    Wrong-Note Rod Poster Extraordinaire
    atlanta
    The tele I just bought was strung with 9s and it played great.... 9s are usually a little light for me, but, perhaps they sort of belong on this guitar.
  10. Beatbx
    Beatbx Tele-Meister
    Eugene, OR
    I love cheap deals on strings too. I've found whatever gauge you prefer, if you set it up or get it set up, you ought to stay with that gauge until the next setup. Once it's playing well a guitar's in a delicate balance. A different gauge can cause unwanted buzzing and/or intonation issues. On acoustics I've found it even more crucial to find the most appropriate gauge and stick with it.
  11. nonvintage
    nonvintage Tele-Holic
    San Diego
    Yep and 10's depending on the tension if it seem too tight with 10's then 9.5 or 9's
  12. Birdmankustomz
    Birdmankustomz Friend of Leo's
    New York
    +1, my main acoustic sounded great for 10 years, then I changed the strings (no, my mother never changed the strings the whole time she had it :rolleyes: ), I've replaced the strings 4 times now and still haven't gotten the right ones yet (not heavy enough so I get buzz on the bottom 2 strings). I just bought a set of 13-56's, hopefully those are thick enough.
  13. acranford9
    acranford9 TDPRI Member
    68 second Avenue
    I use 11-50 tape wound strings (flats for short).
  14. Jim622
    Jim622 Friend of Leo's Silver Supporter
    Philly
    I have 9's on my mex. thinline II and 10's on my mex. standard for slide with
    Open G or Open D tuning.
  15. AngryHatter
    Los Angeles
    Mine has a modern TOM bridge. It might be a whole 'nother story if it was a threaded one.
  16. triviani
    triviani Tele-Meister
    Osaka
    Uhm, I play 11s with the Jaguar, they are hard to bend but they feel right for that guitar. On Les Paul I prefer 10s, because 9s felt a bit floopy to my liking.
    Just got a tele, and put some 10s on it. It's not that difficult to bend but I'm wondering if 9s are not a better option for teles, as with 10s the tension starts to feel a bit heavy.
  17. Prison Rodeo
    Prison Rodeo Tele-Meister
    State College, PA
    9s (- 42 nickel bullets) all the way on my three teles, and my strats too. (Half-round 10s on the Parker, 11 flats on the SJM-62 - for the surf of it - and 12 flats on the ES-125.)
  18. FredJr
    FredJr Tele-Meister
    Prospect, CT
    That's what I found - 9s feel the best on a 25.5" scale guitar (for me)
  19. Twang Tone
    Twang Tone Friend of Leo's
    I started on 9s, but moved to 10s about 3 years ago. Now 9s feel piddly.
  20. Rokatt88
    Rokatt88 Tele-Holic
    Vista, CA
    Yah, I stauted wid da ninze and den I stauted wid da tenz and aufter a vile I work aup to telafone cables. Yah, da real thing. Yah. Like wat yoo see on telafone polez. Yah, yah.
