I thought I read somewhere (maybe on Fender's website?) that the neck is wound a tad weaker than the bridge...?
Just a little. Barely a tad.
I have the neck in my vintera custom and I love it! I have owned a few guitars with the MIM wide range lookalikes and this blows them out of the water.![]()
Is the bridge pickup stock? How does the WRHB match up? And how does it sound in the middle position?
Thanks! Looking for a CuNiFe Custom option that doesn't involve spending $2K.
not sure what match up means
Just meant, does the WRHB overpower the single coil when switching back and forth, or are they fairly well balanced volume-wise?
I just started a conversation with Racer5, I soldered the leads to the same ground and hot lug on the neck volume pot as the stock neck and it appears to be following the schematic included with the CuNiFe pup (that schematic is for the Deluxe-USA build no doub). But mine is definitely out of phase. Sounds just great out of the middle position, and Peter Green-y in the middle. I made some use out of it at the Blues Fest a bit ago, but I would prefer to have it in phase.stock bridge pickup, no need to change it
sounds like a WRHB and a telecaster bridge pickup in the middle position? i don't know how to accurately describe it
I found the bridge to be overpowering the neck and spent some time today adjusting the height of both pickups. I had previously used Telenators suggestions on setting the new CuNiFe pickup and also on my 72 Thinline AVRI where I installed Mojotone 72 Clones maybe 6 years ago. On the Vintera, I ended up raising the neck a tad and lowering the bridge a tad and now the guitar is balanced and in a word ballsy. I was fortunate enough in 1972 to be able to afford a new Thinline that I still have. It is still in great shape, but nearly 50 years old. I was pondering whether to upgrade to the new CuNiFes, but probably will just leave it alone…it has lost some of its punch for sure, so it is a display piece now and brings back memories of some really good times and a particular lovely woman, now long gone, but I have the guitar!Just meant, does the WRHB overpower the single coil when switching back and forth, or are they fairly well balanced volume-wise?
One of the variables is that I don't know is what the pot value is in the Vintera neck. I suspect 250K? The AVRI Mojotone setup has 500K pots and may allow the Mojotone to breathe a little. Your comment on alnico is probably spot on. Many have written on these sites that the mystical CuNiFe is not the sole reason for the tone of these pickups....but, design and construction weighs in heavily. .
