Anyone recognize these pick ups? Squier Japan
Discussion in 'Squier Tele Forum' started by Craig Williams, Oct 20, 2020.
  1. Craig Williams
    Craig Williams Tele-Meister
    Thailand
    1985 /86 E serial Squier Japan Tele
    Anyone know if these pick ups are original or anything about them? Bridge pick up looks pretty stock standard but front pickup has me thrown a bit. No markings. red and white wire with a shield. I didn't post photos of the front but just looks like a bog standard chrome covered tele neck pick up, BHK apparently the brand, Chinese company used by some manufacturers. The three wire thing gets me. Wondering if it could be a split coil?
    The pick up itself has a lot of hum / noise and not particularly good sound.
  2. mkdaws32
    mkdaws32 Friend of Leo's Ad Free Member
    Moncton, NB Canada
    Not an expert, but I would guess that the neck pickup, at least, is not original. I've only seen those "BHK" stickers on more modern import pickups. Someone might certainly know better than me. I have a chinese Squire with those labels and a friend has a duo-sonic with the same stickers.
    EDIT: The third wire is almost certainly a separate ground for the metal cover. This particular pickup doesn't likely have a tap. A separate ground for the cover is sometimes used to make it easier to reverse the phase of the pickup. In a two wire configuration, the cover would be grounded to the negative coil wire instead of providing a separate ground wire.
  3. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    Yeah the labeling on that neck pickup screams import but they look like they're both made with alnico pickups since there is an absence of ceramic bar magnets on those pickups. Xxxxx
    mkdaws32 likes this.
  4. Craig Williams
    Thailand
    I wouldn't be surprised. They do stuff like that here. Pull the original decent pick ups out and sell them separately and replace them with something from a junker. Could well be off a Classic Vibe however CV pick ups better than the sound of these normally
  5. Craig Williams
    Thailand
    I've since discovered those BHK pick ups they use on Mexican Blacktops. Have seen at least 2 with them now. Single coil tele neck style and HB
  6. Billy3
    Billy3 Tele-Holic
    Charleston,Sc
    With only 3 wires? No split. Most likely a separate ground for a 4way switch possibly?
