Anyone play "When the Levee Breaks"?
Discussion in 'Tab, Tips, Theory and Technique' started by BackNtheSaddle, Dec 2, 2012.
  1. BackNtheSaddle
    BackNtheSaddle Tele-Holic
    Philly 'Burbs
    I am working on adding this one to the set list...
    Seems to be in "Open-F". From what I read, it was recorded in Open-G (on an electric 12 string) and then, the tape was then slowed down to make it F.
    So, to recreate it live, I'm wondering whether tuning to Open-F *or* tuning to Open-E/capo-1st would be better. Slide playing in Open-F is really difficult on guitar, so I think Open-E/capo-1st would be easier.
    I know that I could just try it both ways and see for myself... I will do that.
    But, if anyone plays this, I'd be very interested in their...
    Thoughts, suggestions, comments?!?!?!
  2. MonkeyKing
    MonkeyKing Tele-Meister
    Detroit
    I play it in open g, but really it is more about what you can sing or your singer can sing. Go with whatever matches that.l
    I guess you could club up a string gauge, and lower the open g tuning to f, and you`d be at about the same string tension, as opposed to trying to tune UP another whole step from e . . .
    Anyway, great song, great choice!
  3. MickM
    MickM Friend of Leo's Platinum Supporter
    A steel guitar engagment.
    I play it in open g on lap steel but actually like it better played on my acoustic square neck dobro.
  4. Del Pickup
    Del Pickup Poster Extraordinaire
    New Zealand
    Tuning up to open F from open E might put quite a bit of extra tension on the neck of the guitar so you might need to tweak the truss rod and even consider going down a string gauge to compensate for that.
    And the chord shapes in open G are different to open E so you might not end up with it sounding like the original without a bit of trial and error.
    You say in your first post that 'slide playing on open F is really difficult'. Why's that? Unless you have a whole different tuning set up than what I'm thinking of it should be exactly the same fingering as open E. It just takes practice.
  5. BackNtheSaddle
    Philly 'Burbs
    To get to Open-F (as sounded in the LZ version), you tune to Open-G... then drop each string down a whole step. That's when the strings turn to spaghetti.
    I guess you could tune "up" to Open-F, from Open-E, but that changes the timbre of the original recording, as far as playing the changes. And, I'm not liking that much. The alternative that I'm exploring is Open-E with capo on the 1st fret - which is pretty much the same, but keeps the tension the same.
    It's hard for me to play slide in the "Open-G, dropped to Open-F", because of the loose & sloppy strings... well, that and also because I generally suck at slide playing.
    I suppose I could "set up" one of my guitars for slide, with some heavier strings and higher action. But, I often keep the Tele in Open-G for Stones and thought that I would just dial it down to F from that, for this one.
  6. Del Pickup
    New Zealand
    If I were you, I'd just keep your guitar in open G and play it in that key if you can sing it comfortably. The overall sound of open G and E is slightly different and if you already play in open G then any fingering (or sliding) is easier to work out.
  7. BackNtheSaddle
    Philly 'Burbs
    I may have just found an "excuse" to get another Guitar :D
    "But, honey, I need one for slide!!! One that has big, fat telephone cable strings and has the action set high enough to drive a small car underneath!"
  8. fezz parka
    fezz parka ---------------------------
    Del Floria's Tailor Shop
    My favorite version by the late John Campbell:
    Railway Ritchie likes this.
  9. chauncy
    chauncy Tele-Meister Silver Supporter
    scottsburg IN
  10. Railway Ritchie
    Railway Ritchie TDPRI Member
    Amersfoort, Netherlands
    John Campbell, one believer overhere, hero.
    Saw him once as opener for Buddy Guy.
