Anyone know if this is the original speaker in my 1964 Princeton Reverb?
Discussion in 'Amp Central Station' started by vanguard, Oct 13, 2021.
  1. vanguard
    vanguard Friend of Leo's
    Charleston, SC
    it's an Oxford, but i can't find a pic of another '64 that looks exactly like this one.
    nojazzhere likes this.
  2. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    There’s a date code stamped on the edge of the speaker frame. See if it’s still legible.
  3. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    Fender Musical Instruments vs. Electric Instruments would indicate '65 or later.
  4. nedorama
    nedorama Tele-Holic
    465 - 510 on the sticker translates:
    465 - Oxford (this is their manufacturer number)
    510 - 1965, 10th month of production.
    See if it lines up with the date codes of your transformers, etc.
  5. Dacious
    Dacious Doctor of Teleocity
    Godzone
    Just the appearance of that crumbleboard baffle is correct for early CBS but still Blackface.
    Telekarster likes this.
  6. vanguard
    Charleston, SC
    The amp is a '64. If the speaker is a '65, it must be unoriginal. That gives me clearance to source a Jensen C10R
    Jared Purdy and Mexitele Blues like this.
  7. Mexitele Blues
    Westminster, CO
    How did you date it? I was told my Pro Reverb was a '76 and believed it for 20 years until I found a transformer from '77.
  8. vanguard
    Charleston, SC
    '64 date code on tube chart; '64 stamp inside chassis and on top of power transformer, all '64 transformers; no fender badge on grille; FMIC screen print on panel.
  9. Glen W
    Glen W Friend of Leo's Silver Supporter
    CT
    FMIC?
    telemnemonics likes this.
  10. Telekarster
    Telekarster Friend of Leo's Gold Supporter
    Earth
    It's still a vintage speaker and close enough in my book, but I say go for it if you wan't to put that C10R in there ;)
    schmee, vanguard and Intubator like this.
  11. Intubator
    Intubator Tele-Holic
    Bawlmer, MD- Home of the "Mayor Shuffle"...
    465 - 510 Could it be the 10th week of "65? What are the dates of your transformers and tube chart exactly? Possibly a very late '64 or early '65 with a late '64 tube chart/cab and some parts from the bin left over... The speaker does look like it has been remounted or moved a bit based on the markings left from hardware, and the solder joints don't look like they may be original... Does it have a chrome Fender logo on the front? I think the '64's had no logo but '65's have them?...
    corliss1 and Telekarster like this.
  12. telemnemonics
    Could still have shipped in '65 but made from parts sourced in '64.
    FMIC can't be right though?
    FEIC?
  13. Telekarster
    Earth
    Yep that's what I was wondering too, but I couldn't quite work it out in my head ;)
  14. vanguard
    Charleston, SC
    Sorry, Fender Electric Inst. Co.
  15. vanguard
    Charleston, SC
    My issue with the Oxford is that it's really bassy to my ears. I want that bright, scooped, small ceramic-mag Jensen sound.
  16. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    My 64 PR has the same baffle board.
  17. Dacious
    Godzone
    Yes - sorry, I should have said 'for up to CBS BF/SF'. My 68 Drip edge VC had it, was built December 67 with a mix of bits back to 66.
    I know amps past 70 had a more dense particle board that was much more regular.
    It tends to suggest the amp's original including speaker and is a 65 build.
    BobbyZ likes this.
  18. charlie chitlin
    Egremont, MA
    I'd say the speaker is original.
    One could make a good argument for boxing it up and installing one you like better.
    Intubator and nojazzhere like this.
  19. vanguard
    Charleston, SC
    The tube chart code is NL, which, being a December build, perhaps lends credence to the '65 speaker being original.
    The things that still bug me:
    --all the other '64-65 Fender amps with similar Oxford speakers have the information printed on the frame, as opposed to the white info sticker seen on this speaker. Could it be a '75 speaker?
    --the speaker has been mounted other times (the paint damage around the screws suggests this), and the solder joints on the tabs look too have been worked over several times
    The PT code is 606-4-39
    OT: 606-4-45
    Choke: 606-4-45
    So October/early November transformers if my math's right.
    Seems odd to me that the amp would be finished completely by December, but then sit around waiting for a '65 speaker?
    If "510" on the spreaker code means "middle of March, 1965," that would mean it sat around for ~3 months before getting its speaker.
    Telecaster1954 likes this.
  20. telemnemonics
    Or like often happened at Fender, parts of the amp (the chassis?) were built in late '64 but final assembly was in early '65 which does make it technically a '65, but the OP may like the idea of it being sorta pre CBS and like the parts built in '64 better.
    I often enough find the speakers are the most recent date and the transformers are the oldest date in a given amp, as in the speaker date is/ are the next year after the transformer dates.
    IDK if they would put speakers in cabs sitting waiting for a chassis to be built, as opposed to putting speakers in after the chassis was wired up and ready to go? My recollection is the speaker dates are more often the later dates though.
