Anyone ever have a Peavey Bandit lose the drive channel?
Discussion in 'Amp Central Station' started by stepvan, Aug 1, 2019.
  1. stepvan
    stepvan Tele-Holic Silver Supporter
    amherst
    So ... The long and short of it is there is a bandit for sale locally that has lost the gain channel. I was thinking it may be a straight forward thing and was wondering if anyone has experienced this and what was done to correct it.
  2. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Which version of the amp are you looking at? Some of the early ones needed the foot pedal to switch channels, or a modded 1/4 plug that was shorted or switched and inserted into the foot pedal jack to simulate the pedal. I think my Bandit 65 is that way.
    You can use the clean channel to run your pedals -- get all your distortion from the pedals.
    If it's actually broken, Is the price low enough you would be happy with just a 'clean' pedal amp?
    Does it have the transtube feature? As you'll see in the video, he ignores all the drive section of the amp -- perfect for the amp you are considering.
    As for the repair ... it's likely a capacitor or a burned up resistor, if not a broken wire at the jack or the jack bent itself -- most common problems.
  3. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    I once disassembled my Peavey Delta Blues along with the foot switch because I couldn't get the gain channel to work, even though the channel switches tested fine. Google then informed me that the amp's channel switch must be set to the gain channel for the footswitch to work and I felt pretty silly.
    Not saying that's what is happening here but yeah that's probably what's happening here.
  4. rickthescot
    rickthescot Tele-Afflicted
    Clean channel with pedals may be worth the price. I rarely use my Bandit's gain channel.
  5. stepvan
    amherst
    its $35 so it is a no brainer version wise its an older one not a blue or red stripe. and running it clean with pedals is ok too
  6. stepvan
    amherst
    price is right for sure
  7. johnny k
    johnny k Poster Extraordinaire
    France
    That trick is awesome. I didn t know the amp could do that until some member posted that exact same video. Maybe it was you ? i can t remember. But that s worth a try.
  8. schmee
    Not unless they prayed it would go away....
    rangercaster and Big_Bend like this.
  9. stepvan
    amherst
    Well it now is here in my apt, and a little deoxit in the channel buttons on works like a charm, but Way to loud for my current living space so I may send this silver striper to a new home.
  10. stepvan
    amherst
    Nope works good after some contact cleaner action. A bit to loud though for my apt.
  11. Daddydex
    Daddydex Friend of Leo's
    Pennsylvania
    The Bandit is not a apartment amp. :)
    You should have no problem flipping it for a small profit!
    Dan
  12. 3-Chord-Genius
    Winchester, VA
    What's funny about this is that I had one of the mid-1980's Bandit 65 amps (like the one shown below), and when I cranked it up all the way, the drive and clean channel sounded identical.
  13. stepvan
    amherst
    already done! had it sold later the same day and did ok!
    Daddydex likes this.
  14. stepvan
    amherst
    I had that amp years ago as well, got it in payment for a side job I did for a friend. mostly used it clean, cranked.
