chris m.
I'm probably going to experiment with some treble bleed circuit options for my Jaguar. Wondering if anyone has hit upon good values. With some research I found that for using a cap and resistor in parallel, a good rule of thumb is that the resistor value should be 50% to 90% of the value of the volume pot. That would mean using maybe a 500k resistor in parallel with a 1200pf cap, for example. But there is the issue of this style treble bleed affecting the volume pot taper too much. The Kinman circuit avoids that. That's where you put a resistor and cap in series across the vol pots.
I noticed that Fender uses a combination of both. Their website on treble bleeds shows a treble bleed circuit consisting of a 150k ohm resistor in parallel with a 1200pf cap, but also a 20k ohm series resistor in line between the first pot lug and the parallel bleed circuit. This circuit I think was designed for Strats and Teles with 250k pots, so I'm thinking of starting with the same concept, but probably bumping up the parallel resistor to around 330k or 500k ohms, and leaving the series resistor at 20k ohms. I'll use alligator clips and a breadboard so I can mess around pretty easily until I hit on the values.
But if anyone has done this and found a good solution please let me know. If I hit upon a good solution I'll post the results. I wish I had some trimpots on hand since that would make it even easier!
