Any which way but telecaster
Discussion in 'Tele Home Depot' started by restorationad, Sep 12, 2012.
  1. restorationad
    restorationad Tele-Holic
    RTP
    Working on finishing up the red witch 2. Setting the neck.
  2. restorationad
    RTP
    Neck set cleaning up the heel.
  3. restorationad
    RTP
    Pretty easy to reach around.
  4. restorationad
    RTP
    On to the T9 Blackguard pickguard. Template first.
  5. restorationad
    RTP
    The dual blade neck pickup needs a bit larger hole than a traditional SC. The coil wires are not soldered up yet but I needed to make sure it fit.
  6. restorationad
    RTP
    Now lets fix the body carve I don't like.
  7. restorationad
    RTP
  8. restorationad
    RTP
    Clamping up a body fix is always tricky
  9. restorationad
    RTP
    Fixed. I had to put the belly carve back because a bit of the original one was still there.
  10. restorationad
    RTP
    On to decals. Since this is going to be a beater prototype thing I want the decals to look worn out. Also wantto make it look like I didn't sand the pine 2x8s I used for the body so we will add some marking to them as well. After that we will seal the body up with CA.
  11. restorationad
    RTP
    Once it is tested I will get some orangish butterscotch clear on this thing to make it look right.
  12. restorationad
    RTP
    Decided to angle the runings keys and stay with the vintage style.
    Late night wiring.
  13. restorationad
    RTP
    Assembled to work out the kinks before going to finishing. No finish yet just sealed in CA to keep the moisture out. Still need to finish pickups, decide on pickguard screws, and fit controls into cavity better.
  14. restorationad
    RTP
    Guitar is still very light colored. Once the finish goes on we should get better contrast between the parts. Also not sure about the half bridge.
  15. crazygtr
    crazygtr TDPRI Member
    PR
    I would play that "beater" any time, in fact for me it looks like a tele in a futuristic movie.:D. By the way how thick is that body? is the same as the s ones?
  16. restorationad
    RTP
    So it is right at 35mm. That is 1-3mm thicker than an S9 but it is super light. The pine is the reason. It is White pine 2x8s so very light. Yellow pine is a bit heavier. I am going to go ash on the production models (seems wrong to ask for money for a guitar built from Lowes 2x8s).
    5lbs 7oz without knobs and a tone bar to hold the strings.
    Add those two items and some wax in the pickups and finish... this thing might still be under 6lbs.
    The guitar is acoustically loud right now with little to no finish on it. It is really overly alive \m/. The pickups are not potted and it really has no finish. I stuck some Ernie Ball Cobalt .010s on it (I hate these strings) and it has tons of pop. I found myself repeating the opening riff to "copperhead road" for some reason.
  17. restorationad
    RTP
    Aussie blackwood... Vic and Taz. With a ringed Gidgee fretboard to boot. No plan yet but glad to have them.
  18. restorationad
    RTP
    Starting on 2 new multiscale 7 strings.
  19. restorationad
    RTP
  20. restorationad
    RTP
    Needed a switch knob for the Blackguard. I could order one but this is a cheap prototype so lets grab a piece of ABS and make a knob. Can't be that hard. I didn't use the drill press to drill the hole so the first 2 ended up being a bit crooked. After finally getting a straight hole I rounded it on the belt sander, sanded it with a 180 grit sponge and buffed it on the buffer wheel.
