Any which way but telecaster
Discussion in 'Tele Home Depot' started by restorationad, Sep 12, 2012.
  1. restorationad
    restorationad Tele-Holic
    RTP
    Sand through? Ummm... Teak oil is not a finish that builds. If you are building a finish with teak oil you are doing it wrong. Teak oil has varnish and dryers in it. It is not a film finish. It is meant as an oil finish for oily stubborn woods not as a film finish.
    Yes. And this season coming up no. I use oil finishes on the woods that can handle oil. Cocobolo, Bloodwood, Ebony, etc... as tops are great with oil. I think next year I am doing a bunch of tops that require gloss.
    Ziricote needs a gloss finish. Maple needs a gloss finish. For those I use Nitro.
    Just bought a new buffing rig that allows me to get a very professional shine on my Nitro. Makes me happy.
    As for the fretboards. I have had pretty good luck with Behlens fretboard oil or using Behlens Teak Oil. There is not a lot of difference between the two other than cost. Putting a oil/varnish mix on a wood that enjoys oil is ok. Put oil on cocobolo at your own risk. With the oily exotics I always have to use an oil with drying agents in it.
  2. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    Whoops.:oops:Yeah I read that somewhere else, but had no idea what it meant so ignored it, thats why im asking:D
  3. restorationad
    RTP
    Sand off whatever you have built up. You can use teak oil as a lubricant for the wet sanding.
    Wipe the excess off. Watch the body for a few hours and wipe up anything that seeps to the surface over that period.
    Hang it up to dry for a few days until it stops smelling like oil.
  4. restorationad
    RTP
    The descision.
    Last week I got the brilliant idea to put an ebony head plate on what was supposed to be a quick dirty practice neck for the CNC machine. I was looking for another T9 (tele style) guitar so I could finish up that model and say it was ready for production. Then this happened.
    I dug through a pile of tops and found a killer quilty flame maple top. Problem is it will only work for an S9 (super strat) body. Honestly the neck looks so slick that it must be a super strat. I can not envision it as a single cut anymore. Worst part about this is I have no room for anymore S9 guitars in my study. That means someone has to go, probably this one. I miss it already and it isn't done yet.
  5. restorationad
    RTP
    On to the one that is leaving. Getting the fretboard glued down. Now that I am sure of the CNC process I can just do this.
  6. restorationad
    RTP
    Not sure how this happened but the epoxy ran into the fret slots and ran under the tape on the headstock as well. It never ends...
  7. restorationad
    RTP
    The top is also glued together and on the body.
    Speaking of production here I get several trussrods set in future necks.
  8. restorationad
    RTP
    And I finally bit the bullet and started using the CNC for my fretboards. This is just an experiment and we will see how it goes. But slotting multiscales is still a chore even with my template system. So I am going to try this.
  9. restorationad
    RTP
    More multiscale pickup bobbins. ABS halves glued together with PVC glue.
    Side project... Wenge salt and pepper napkin holder.
  10. Barncaster
    Northern California
  11. restorationad
    RTP
    Neck for the Red Witch II fresh from the CNC
  12. restorationad
    RTP
    And on to the body cuts.
  13. restorationad
    RTP
    While the CNC is running the body it is time to work on the headstock and fix the frets that are full of epoxy.
  14. restorationad
    RTP
    Glued up the head plate.
  15. restorationad
    RTP
    What is the CNC doing anyway?
  16. restorationad
    RTP
  17. restorationad
    RTP
    Prepping the body blank for the unnamed guitar. The top and blank are really close to the size of an S9. I had to use the template and make sure it did not slip or move during the glue up.
  18. restorationad
    RTP
    All glued up
  19. restorationad
    RTP
    On the CNC we get a look at the body sides for the first time.
  20. restorationad
    RTP
