Any Plumbers here?
Discussion in 'Bad Dog Cafe' started by 2HBStrat, Sep 20, 2021.
  1. 2HBStrat
    2HBStrat Tele-Afflicted
    Four Rivers Area of Middle America
    I have a leak in a bathroom sink. So I checked Google on how to fix it. I turned the water off, took the knob off, unscrewed the screw thing, then popped out the other thing, the plastic washer and spring. Then I replaced them all. Improved but still leaking. Now I'm sitting here with my water turned off.
    Is it time to call a plumber?
  2. Harry Styron
    Harry Styron Friend of Leo's Gold Supporter
    Branson, Mo
    Is this a single-handle Delta faucet that is leaking? Do you mean that it drips in the off position or it leaks elsewhere?
    Or is the drain leaking?
    Aren’t there shutoff valves for the faucet only so that you don’t have to shut off the water for the whole house?
    Obsessed and dented like this.
  3. tap4154
    tap4154 Doctor of Teleocity Ad Free Member
    Southern California
    Hard to say without seeing pictures of what kind of faucet you have there. If it's a cheap faucet, often they aren't even worth trying to repair. By the time they leak there's so much corrosion it's not even worth trying.
    If it's the kind that is in three separate holes, they can be a little tricky to install, but if it's a one-piece unit they're fairly easy to install. You'd probably save a lot of money if you didn't call a plumber and just installed one yourself, if you have a little bit of skills.
    But if you do call a plumber, just don't call one like George Brazil, where the plumber only makes a tiny portion of what they charge. Go on the nextdoor app or something else like that, and just find a guy working on his own with good reviews.
    TomBrokaw likes this.
  4. Sparky472
    Sparky472 Tele-Holic
    Austin, TX
    Not a whole lot of info to go in in your post but you might need to replace the seat as well, not just the cartridge and o-rings. You can see what that is in this video:
  5. 2HBStrat
    Separate handles for hot and cold. The cold is leaking pretty badly in the off position. There is no interior shutoff.
  6. tap4154
    Southern California
    I've never seen a bathroom sink faucet that didn't have shut-off valves under the sink. Are you sure there's no valves under the sink?
    Obsessed, SnidelyWhiplash and decibel like this.
  7. Harry Styron
    Branson, Mo
    I’d go tonight to the nearest big-box store and buy a new faucet for $40 and replace what you’ve got and get out of a jam. You can get a better faucet next time.
    tap4154 and TomBrokaw like this.
  8. stxrus
    stxrus Poster Extraordinaire
    St. Croix, USVI
    There should be angle stops to shut off the hot and cold water to the fixture.
    Make sure the cartridge you are replacing is the correct one. Also some silicone grease on the o-rings helps
  9. decibel
    decibel Tele-Meister
    The Mountains
    Exactly. Instead of turning the water off in the entire house just turn it off under the sink for the faucet that's leaking.
    Speaking of those valves, I turn mine about halfway "off" to restrict flow (we have too much pressure, even with a pressure regulator). Will this cause damage to them?
  10. tap4154
    Southern California
    No that shouldn't hurt them at all. In fact angle stops should be turned on and off once a year, just so they don't freeze. But having it halfway turned on won't hurt it. Although I have seen some of the twist down valves that leak in between on and off. Quarter turns normally don't.
    posttoastie and decibel like this.
  11. trev333
    Coolum Beach,Australia
    No..not a Plumber..:rolleyes:...
    but, I've just been under the house cutting in a new grey water diverter tap under my sink drain pipe to run the water out into the garden....
    works a treat...:)
    Obsessed likes this.
  12. Engine Swap
    Engine Swap Tele-Afflicted
    Chicago
    Replace the cartridge or get a new faucet. Replacing o-rings and washers has been a fool's errand IMO.
  13. mfguitar
    mfguitar Tele-Afflicted Silver Supporter
    Buffalo
    If your faucet is like the type in Sparkey's picture (Delta or Delta Clone) your cartridge could be worn and not just the seat and springs. If it is all plastic you might be able to polish the surface flat if it appears worn or replace the entire cartridge. You can inspect the faucet when you have the stem out to see if there are any defects in the body or debris under the seats. If you don't have valves under the sink it would be a great idea to install some while the water is shut off. If all else fails put a new faucet in.
  14. 2HBStrat
    I think it would be beyond my "skill" level. And I don't have great tools, either.
    Yes...
    As I said, there aren't any.
  15. 2HBStrat
    That's exactly what I did except mine has a spring and a rubber sleeve that goes over it that the cartridge sits on. The old sleeve had a small tear which I guess was the problem. I did have some improvement but it is still leaking a steady stream. Is there anything else I can try before starting to look for a handy man or plumber?
  16. tap4154
    Southern California
    Then I would look for a independent plumber, and again stay away from the big places like George Brazil. They'll charge you an arm and a leg.
    To be honest, changing out bath sink faucets can be very difficult. If they've been on there a long time, sometimes I have to cut them off. Also can be very difficult to access depending on how your cabinet is built. And if you change out the drain pipe and sink flange, that can be a real challenge as well.
    Would be nice if you'd post a picture, of the faucet and underneath. I'm very curious because I've never in my 40 years of working seen a bath sink faucet without angle stops underneath the sink.
  17. pinchegil
    pinchegil Tele-Holic
    Roxborough Park, CO
    If you hire a plumber or handyman, and there truly are no shutoff valves under the sink, have him put them in
    Obsessed and tap4154 like this.
  18. stomped box
    stomped box Tele-Meister
    varies
    I'm not even sure how you could do that in modern times, or it to have been done that way and stayed that way without needing repair for such a long time and no one ever doing it right. Everything on the fixture end is threaded. You wouldn't be able to finish plumbing the place and turn the water on until all the fixtures were in and you'd run copper to the bathroom sink, and somehow soldered the plumbing in place behind the bowl.
  19. pinchegil
    Roxborough Park, CO
    Soft copper, flare tool, and the correct flanges/or compression fittings. I have seen it done
  20. Obsessed
    Montana
    Yup, you need a plumber. Watch the plumber do the job and learn from it for the next time. I have five sinks and five different assemblies, so unless it is a very traditional, very modern home, you could end up with a mess that will cost even more by the time a plumber is called to fix.
