Mongo Park
I’ve re-aligned voice-coil formers in speakers that had rubbing coils, so 1/2 way.
so briefly how do you realign a voice coil
Cut off the dust cap. Shim the voice coil with card stock. Fill a small solvent safe Container with acetone and put it on the magnet. Cover the voice coil area and let the acetone evaporate (i let it sit overnite). Remove shims. Re install dust cover if the coil is freed up. I also brushed acetone around the spider-cone junction, but not sure if that’s common.so briefly how do you realign a voice coil
Yes, without the tool is not a real problem. But, with the tool is spot on every time. Three different parameters are aligned concurrently. The centring of the voice coil former, the height setting of the coil windings between the poles, and most importantly for a long excursion of a wide diameter 2" former - that the former is absolutely squarely set. And this simple tool masters all three in one swoop, holding everything in position as the spider and cone are moved into position, and the glues are applied and left to set. Sure, I could get by without it, but I'm damn glad I've got it.Regarding the "not available" alignment tool:...........
Cut off the dust cap. Shim the voice coil with card stock. Fill a small solvent safe Container with acetone and put it in the magnet. Cover the voice coil area and let the acetone evaporate (i let it sit overnite). Remove shims. Re install dust cover if the coil is freed up. I also brushed acetone around the spider-cone junction, but not sure if that’s common.
The acetone softens the glue enough to re-align the vc /spider/ cone alignment is my understanding.thanks man, this will be a big help
I tried shims and lightly sprites some water on it but limited success
