Any experience at storing teles in 120 deg F heat?
guitar_paul1
washington state / SoCal desert
I'd like to store my Squire MIC Affinity in SoCal (I-10 eastern desert) over the summer, but I'm afraid of what it will do to the neck. Any suggestions?
The backstory:
Humidity is real low and temp is real high over the summer in my trailer.
I stored an Ibanez AC240 acoustic down there last summer and destrung it but I left the truss rod cranked. When I got back in the fall, the neck had a pronounced unplayable back bow. Fortunately, the neck had excessive relief even with the truss rod tight, so it essentially cured it like putting a heater on and straightening it. The bow came out with loosening the truss rod and putting on some 0.012 strings.
The tele, however has a perfectly straight neck.
I guess one option would be loosening the truss rod and loosening the strings.
ElJay370
Los Angeles, CA
Indoors, in a case, with the strings slacked should be fine. A bolt on solid body isn’t anywhere near as sensitive to environment as an acoustic. I’d expect a bit of easily remedied fret sprout when you finally do retrieve it, but not much else.
Billy3
Charleston,Sc
I don't recommend it. Lived in Tucson, AZ for 6 years. Wood does lots of crazy things in a dry environment. What ever you do, don't take the strings off. Maybe tune down a half step. If you have a hard case wrap it in plastic. Also place it in the center of your unit away from the most direct heat. Still a gamble.
Happy Enchilada
Gold Supporter
God's Country
prod_24189741312
Peegoo
Beast of Bourbon
Guitars generally do best where us human beans are comfortable. However, 120-degree heat will not kill a guitar. Excessive heat and moisture sure will.
Do the following.
-Clean the guitar well, and leave the strings on.
-Detune each string one full turn of the tuner knob.
-Place a layer of toilet paper between the strings and the frets.
-Place the guitar in its case.
-Store it flat, under a bed, with the guitar face up.
"Under a bed" is far better than in an attic (too hot) or in a basement (too damp).
Boreas
Adirondack Coast, NY
You could try using a humipack. in the case, and seal the case with garbage bags or any big plastic bag. Really depends on how dry it is going to get. I would avoid rapid changes in heat/humidity. I don't think rapid cycling would be advisable.
