Any DOWNSIDE to a Bakelite pickguard?
Discussion in 'Tele-Technical' started by Boreas, Apr 10, 2021.
  1. Frisco 57
    Frisco 57 Tele-Meister
    Arlington WA
    I don't think they come clear coated.
    Boreas likes this.
  2. netgear69
    netgear69 Tele-Afflicted
    england
    Depends where you get it most will just be the raw pickgaurd if so just get yourself a 250ml rattle can
    Boreas likes this.
  3. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    You can get it in cream color if you look around.
    The pickguard is also called a scratch plate because it is designed to get scratched--instead of the painted body. If scratches are a problem wear mittens and play fingerstyle ;)
    Regarding clear coats on phenolic sheet: bare sheet goes a lot longer before scratches start to show. Clearcoating it makes the scratches more apparent.
    Boreas and Dan German like this.
  4. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    I’ve had a Bakelite guard on mine for years, and the only downside I’ve found is that I can no longer match the clicks of static electricity to my metronome to keep time. :D
    Gevalt likes this.
  5. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    It's a similar product.
    Garolite and Micarta are brand names for a phenolic based material that is built up with layers of paper, or fabric infused infused with a phenolic resin.
    As I understand it, Bakelite is an un-reinforced type of cured phenolic resin - it doesn't have the paper or fabric layers to it.
    For Micarta and Garolite's reinforcing layers, different types of paper are used, or different fabrics like linen or canvas or even fiber glass (G10), depending on the exact product.
    Richlite is a trade name, and it's made in similar fashion from resin infused paper.
    Garolite XX is a paper based material very much like Richlite.
    Carbon fiber fabric is used in a similar way too.
    I started using Micarta about 30 years ago for high-performance knife handles - knives that can't fail ;)
    The stuff is basically bullet-proof :).
  6. old wrench
    This is what it looks like in the rough state -
    The black is 1/16" thick Garolite XX.
    The brown is various thicknesses of canvas Micarta.
    The light green is fiber-glass reinforced G 10.
    All of it is very durable.
    I've used the brown and green stuff in place of steel or aluminum in different fabrications :).
    You can also get this stuff in a pretty wide variety of colors and different reinforcing materials.
    edit:
    I think you can see from the picture that the black Garolite XX is not an absolute black - it has a slightly mottled color to it and a very slight texture.
  7. edvard
    edvard Friend of Leo's
    Bremerton, WA
    Thanks for the heads up; I was jonesing for black pearloid, but I dig the Bakelite look pretty well also.
    Poking around the MCMC website, I happened upon Conductive Garolite CE, with embedded Graphite. Would this make good nut material? Seems hard enough, and the Graphite would reduce friction/wear in the string slots. A 12" x 12" sheet would make a LOT of nuts. Hmmm...
    Boreas and old wrench like this.
  8. old wrench
    That McMaster-Carr website is like a rabbit-hole for me :).
    What a variety of building materials and parts!
    You could certainly cut a nut from Garolite, and it would work, but I don't know which type would be the best choice.
    There are other materials that M-C sells that might be a better choice.
    They also sell Nylon 66 which is what Gibson used to use for some of their nuts and saddles.
    moosie and edvard like this.
  9. edvard
    Bremerton, WA
    It was the Graphite part (https://www.mcmaster.com/plastics/shape~sheet-and-bar/slippery-conductive-garolite-ce/) that got me thinking, but I'll look at the Nylon too. Ovation solid-bodies back in the day used Nylon saddles and I was never impressed, but maybe it's better than I think...
    old wrench likes this.
  10. radiocaster
    europe
    Well they are flammable, supposedly.
    Gevalt and Boreas like this.
  11. Preacher
    Preacher Friend of Leo's
    Big D
    Garolite from McMaster Carr - sprayed with Sherwood Clear Lacquer.
    It is going on 15 years now, no cracks although the finish is slightly altered.
    old wrench and Boreas like this.
  12. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Would you bother with the lacquer again?
  13. Preacher
    Big D
    Absolutely. It took all of fifteen minutes when I was spraying the guitar body.
    It even has the paint can "halo" on the backside from where I had it setting.
    I did sand the pick guard down before shooting the top coat but it made the guitar look "right" when it was finished where the raw bakelite looked, well "raw".
    You can't get that nice wear if you don't clear it first!
  14. Frisco 57
    Arlington WA
    I was saying that they'll crack on the corners if you tighten the screws too much. I just took a close look at my old one and now I can add..."like this!" Oh well...
  15. Fretting out
    Land of Mary
    Fender tortoise picks are flammable too
    They look like sparklers if you light them on fire
    I guess the picks are actually some type of cellulose
    Pickguards I don’t know
    Boreas and radiocaster like this.
  16. SixgunElectric
    SixgunElectric TDPRI Member
    Alternatively, one could also consider using the vulcanized fiberboard type material like in the earliest blackguard examples..
    Just sayin'....
    Boreas likes this.
  17. Boreas
    Are any available in that material??
  18. old wrench
    If I'm not mistaken, that's the same stuff we've been talking about :).
    Some folks call it "bakelite"
    Some call it "garolite"
    And some call it "micarta"
    But it's all pretty much the same product - with different brand or trade names.
    It's phenolic resin infused paper subjected to heat and pressure to cure it.
    When we were discussing it last week I looked around for another source besides M-C and found this:
    Sheet .062" Thick Grade XXX Black Paper Phenolic 18" x 24" Knife Spacer Micarta | eBay
    For some unknown reason, I can't add any other links to this post, but that seller also has 12" x 12" x 1/16" pieces for $12 bucks including shipping ;).
    I'm sure there are other sources for it as well. I found these with a quick search, and don't know anything about the seller, good or bad.
    You can only get one pickguard out of a 12" x 12", but you can get three from a 12" x 24" piece and you might be able to five from a 18" x 24"
    You'll have some left-overs which can be used for other stuff like pickup surrounds or control covers.
    It cuts, files, and sands somewhat like wood - I usually use a scroll saw for cutting, but any finer toothed saw blade will usually do a good job.
    I've never used a router on it, but I'm sure a router would work OK.
    It's relatively thin at 1/16" so I don't put a true bevel on it, instead I cut the edge square and then just ease the edge - take the sharp corner off - it with a smooth file or sandpaper, which looks like the same way Fender it.
  19. EsquireOK
    EsquireOK Poster Extraordinaire
    U.S.A.
    More expensive than ABS/PVC, when ordered from a pickguard maker.
    Looks bad unless clear coated...then clear coat wears off.
    A bit more difficult to work with during construction (but not your issue if you aren't making it).
    Can chip and be more brittle than ABS/PVC.
    These are not drawbacks that should keep you from using one. They in no way outweigh the great look, IMO. Lacquered Garolite (what you are calling "Bakelite") is one of the main guard materials that I use in my builds and assemblies.
  20. Texicaster
    Texicaster Friend of Leo's
    It Varies.....
    Catalin is kind of colored bakelite but I don't recall seeing it in sheets.
    https://en.wikipedia.org/wiki/Catalin
