Any computer people here? Have Windows 7 driver, want to use on Windows 10
Discussion in 'Bad Dog Cafe' started by David Meiland, Jul 16, 2021.
  1. David Meiland
    David Meiland Tele-Meister Silver Supporter
    Friday Harbor, Washington
    Can't think of a forum where the people are smarter and know more than this one, so here goes.
    I have a USB device from years ago, with a driver for Windows 7. I now only have Windows 10 machines and can't get the driver to install on them. I did some googling and found a possible solution that doesn't work (right-click on it, select "troubleshoot compatibility", select "it worked on an earlier version of Windows"... etc.).
    Anyone know a workaround for this?
    This is the device in question: https://www.ueitest.com/ECommerce/product/thl2/thl2
  2. richa
    richa Tele-Afflicted
    In general driver support is the least likely to be backward compatible. Will vary from case to case and I know of no generic approach that will reliably work. Best thing is to go to the device mfr website and hope they have an updated driver. But don't hold your breath.
    Henley and JL_LI like this.
  3. TomBrokaw
    TomBrokaw TDPRI Member
    Give 'em the beans!
    What happens, exactly? It fails silently? You get an error message? It says it was successful but doesn't recognize the device?
  4. Guitarteach
    The unfashionable end of the Western Spiral Arm
    2012 looks like last time it was updated.
    Can you see it as a USB drive to open. The logging data may be extractable manually into Excel or something if you can see files.
    bgmacaw likes this.
  5. Alamo
    Alamo Doctor of Teleocity
    Berlin
    Have you installed the software first?
    Software Installation
    The THL2 comes with software that must be installed before the device can be used. Insert software CD into computer and follow the install instructions. After installation, place unit in the PC USB port to begin download data.
    Is there a right click option to install with Admin rights in Win10? I'm still on Win7.
    the data sheet says:
    HL2 is compatible with computers using windows™ 2000, XP, Vista, 7, 8 and 10.
    so there must be way.
    https://www.ueitest.com/ecommerce/site/content/PDFs/THL2/THL2_WDS.pdf
  6. nojazzhere
    nojazzhere Doctor of Teleocity Ad Free Member
    Foat Wuth, Texas
    I've tried Google Translate on this thread, and I STILL can't understand a word you guys are saying> ;););)
    SecretSquirrel likes this.
  7. memorex
    memorex Friend of Leo's
    Sweet Lorain, OH
    From listing on Amazon.com:
    Can I use this with Windows 10
    Answer:
    Hi,
    Yes, the THL2 is compatible with Windows 10. Let us know if you have any problems by calling Samantha Cook, 503 469 2101.
    Best,… see more
    By UEi Customer Support Manufacturer on January 9, 2017
    Good luck.
    Greggorios likes this.
  8. David Meiland
    The software installed just fine. However, when I try to run the installer for the driver, there a big red warning dialog box from InstallShield Wizard that says installation has been blocked for my protection, please contact administrator (or course I am the administrator). When I first put the device in the USB slot the computer took a moment to think about it and then said "your new hardware has been installed" but the software says it can't contact the device.
  9. David Meiland
    You can't configure the logger to start recording data without the software being able to contact it.
  10. Alamo
    Berlin
    Nope, You need explicit Admin rights.
    any old installer could run it's course when you're the everyday Admin. it's blocked for a reason.
    As I'm not on Win10, I don't know how. I'll be waiting Win11 to get back on track.
  11. TomBrokaw
    Give 'em the beans!
    Try right clicking on the installer and select Run as Admin
    Alamo likes this.
  12. Guitarteach
    Or try this....
    Windows 10 enforces driver signatures by default. This can be disabled to install drivers that are not digitally signed. Use the following steps to disable driver signature enforcement.
    1. Click the Start menu and select Settings.
    2. Click Update and Security.
    3. Click on Recovery.
    4. Click Restart now under Advanced Startup.
    5. Click Troubleshoot.
    6. Click Advanced options.
    7. Click Startup Settings.
    8. Click on Restart.
    9. On the Startup Settings screen press 7 or F7 to disable driver signature enforcement.
    Your computer will restart and you will be able to install non-digitally signed drivers. If you restart your computer again the driver signature enforcement will be re-enabled.
    David Meiland and Henley like this.
  13. David Meiland
    Thank you, tried, did not change anything but it's good to know about that. Here is the dialog that pops up. I'll call the manufacturer Monday and hopefully they have a current driver for this, since they still sell them.
  14. 440mhz
    440mhz Tele-Meister
    Englehart, On, Canada
    I had the same problem awhile ago and I did some research and the solution was to turn off Windows built in defender. It thought it was malware but was a driver too. Worked for me.
  15. SomeGuyNamedRob
    SomeGuyNamedRob Tele-Meister
    Ottawa, Canada
    This.
    For driver installs, even compatibility mode won't help.
  16. TomBrokaw
    Give 'em the beans!
    Looks like it might still be in the ZIP file - try dragging the installer to your desktop and run it from there, normally and then as Admin if needed.
    Side note: Windows key + Shift + S lets you take a screenshot.
