Any 52RI owners keep the "original" wiring scheme?
Discussion in 'Telecaster Discussion Forum' started by E5RSY, May 11, 2016.
  1. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Just curious.
    Scott
  2. Twang Tone
    Twang Tone Friend of Leo's
    Presumably, you're talking about the pre-2012 version, 'cos since August 2012, the 52RI Tele has came stock from the factory with the modern wiring configuration of bridge/both/neck pickups.
    If so, then yes, I did, for a while at least. I had several older 52RIs on which I was able to balance the switch between the bridge and middle settings to engage both pickups. Which was fun for a while...
    But when that starts to feel like a chore, I got the soldering iron out, re-wired the switch to modern, and never looked back.
    But yeah, I kinda liked the funky old wiring scheme with the pseudo bass sound on the neck pickup.
    Just for the record, I've also now converted my Nocasters' wiring scheme from Blend to Modern.
  3. The Ballzz
    The Ballzz Tele-Afflicted
    Las Vegas, NV
    Hmmm,
    Could you please inform the uninformed as to what the "original" scheme was and what it did?
    Thank You,
    Gene
  4. Twang Tone
    Sure. The 'original' wiring scheme of the older (1982-2012) 52RI Teles reflected the vintage wiring scheme of the old Telecasters of late '52 to '66. This meant, when pushed all the way back, the switch engaged the bridge pickup with volume & tone, the middle setting was neck pickup with volume & tone, and all the way forward was neck pickup with a bassy .05uF capacitor engaged to induce a pseudo 'Bass' guitar sound, similar to the neck pickup with the tone rolled all the way off. So essentially, you couldn't get the sound of both pickups on, unless you balanced the switch between positions 1 & 2. Most '52RI owners (including me at the time) re-wired the switch to modern wiring (neck/both/bridge pickups).
    Since about August 2012, with the introduction of the newer 52RI Teles (model 011-0202-850), Fender has shipped them with modern wiring as standard.
  5. rebelwoclue
    rebelwoclue Poster Extraordinaire Ad Free Member
    kentucky
    No- first mod I did to mine was to change the cap and the wiring to the modern configuration. The neck position is way too dark.
  6. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    Rewired mine to the modern version.
  7. The Ballzz
    Las Vegas, NV
    Thank you Mr. Twang Tone. Given that info, switching to modern (and/or 4-way switch) seems like a logical no-brainer!
    Thanks Again,
    Gene
  8. AndrewG
    AndrewG Friend of Leo's
    Exeter, England
    You know I would love to try a Tele with the original 'original' switch wiring-the tone control acting as a blend pot. I imagine there are some unique sounds to be found that way. It worked like this as I understand it: Neck position pickup=pre-set bass tone, no tone control. Middle position=Neck alone, natural tone, no tone control. Bridge position=Both pickups on, tone control acting as the blend between neck and bridge.
  9. MilwMark
    near Arnold's
    It's funny - I don't have a '52RE but I also almost never use the middle position (unless I flip there by accident). I'd probably keep the "old" wiring. Though I'd want to change it so:
    -back = bridge
    -forward = neck
    -middle = bass
    So guess I wouldn't have kept it after all!
  10. rocking rooster
    rocking rooster Tele-Holic
    Somerset UK
    Mine came wired with the modern set up and I've never felt the need to change it back
  11. WhitW
    WhitW TDPRI Member
    Atlanta, GA
    What... if you put a 4 or 5 way switch into the 52RI wiring, so that way you didn't have to balance the switch in between positions, and it would naturally lock there itself? I don't think it even changes the wiring at all.
    Is there anyone here who's tried that?
  12. peteb
    peteb Friend of Leo's
    Cascadia
    I left mine stock.
    I almost always play on the bridge pick up, the neck a little, both pickups even less. For me the inbetween position is fine for both pickups. I don't mind having another sound available, the preset bassy sound.
  13. kinkstah
    kinkstah Tele-Afflicted
    Brittany
    Same here, not for the sake of the preset bassy sound (which I have no use for), but because I rarely play with both pickups on (for me, it's bridge or neck).
  14. AxemanVR
    AxemanVR Tele-Afflicted Ad Free Member
    Minnesota USA
    I have two 52's right now... a 2003 and a 2011
    The 2003 is stock while the 2011 has the modern wiring.
    The funny thing for me is that I almost always play with both pickups on, so it doesn't make sense for me to keep the original wiring in my 2003 - plus I hate the muffled neck pickup setting! - yet I still have it for some sort of nostalgic reason... I guess to give me that "old school" vibe.
    I'm also a little paranoid that if I change the wiring circuit it will somehow degrade the delicious tone I'm now getting. I know this is probably silly, but it's sort of like shaving your head... what if it doesn't grow back?!? :eek:
    Ricky D. likes this.
  15. BuckSatan
    BuckSatan Tele-Meister
    When I bought my '52 RI it was wired in the old fashioned way and I quite liked it for ebow sounds - the lower volume and darker tone compensated for the strength of the ebow.
  16. Tonetele
    South Australia
    I know a guy with a genuine '54 Blackguard. He is a sometimes member of this forum and has a store of vintage instruments.
    He kept all original parts and wired it the new way- I agree with him.
    Why keep a relatively useless circuit??
  17. AlbertaGriff
    AlbertaGriff Tele-Afflicted
    When I was contemplating buying my 52RI, I thought I would be inclined to keep it the way it came... vintage wiring. However, it only took me a day or two before I went out and bought a soldering iron and 'fixed' it.
    I know it's not identical, but you get just as bad of a sound in the neck pickup with the tone rolled all the way off.
  18. T Prior
    T Prior Poster Extraordinaire
    Charlotte NC
    I own two, both are the modern wiring.
  19. valiant
    valiant Tele-Holic
    Burslem
    Got a 52 "Thinskin" original wiring scheme....kinda like it that way....it's part of the charm.
  20. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    I like B+N parallel, can't stand the old "mud position". No brainer.
