A correctly sealed and painted body made of 1 piece Pine or any other wood, will not, cannot, absorb enough moisture to warp under normal circumstances.
Now if you want to "press the envelope" yeah... sure.... but consider, it takes about 1 year per inch of the wood's thickness to correctly dry, so roughly 2 years for a typical body. You can assume the reverse is correct, that under normal atmospheric conditions it will take about 1 year per 1 inch to absorb moisture IF the entire surface of the body is exposed consistently to increased humidity. Seal the rascal, and there is no way enough moisture can creep into the screw holes, or other areas where the raw lumber may be exposed.
If the body is exposed to heat, or cold on one side, that can make the wood fibers on the exposed side expand (heat) or contract (cold) and cause some miniscule cupping, but that would take a lot of exposure.
But generally as long as you are not absurdly careless in the care of your guitar, you’re gonna be fine.
The last thing, internal stresses resulting from growth can cause the wood to warp, but in a typical body, the wood has been cut to thickness and laying around long enough for any of that sort of foible to surface. If you harvest your own lumber, I would put it in the attic, and as long as you remember it’s up there, it’s not ready. Once you forget it (several years) then it might be about ripe.
Ron Kirn
