Anti-meranti? Let's find out
Discussion in 'Tele Home Depot' started by Mat UK, Nov 25, 2015.
  1. Mat UK
    Mat UK Tele-Afflicted
    London, UK
    Warning this will probably be quite tedious...
    Following on from my thread questioning the suitability of different woods for necks - I'm cracking on (or not hopefully!) with a meranti neck build, against general advice...
    Customary materials list:
    - light/mid red meranti neck
    - Gabony Ebony finger board
    - An undecided dual truss rod
    As suggested by Guitarbuilder I've picked up an ebony finger board for strength at only £4. £4 because it's got a tiny woodworm hole and more concerningly a twist in one corner... I'm keeping it cheap... And difficult
    I've started on the finger board - pics to follow
  2. Mat UK
    London, UK
    This is twisted
    Here's a crap pic of the twist in the ebony: you can just about see that the back right corner twists up. I can plant three corners on a flat surface with the corner twist lifting gradually about half way down lifting up to about a 5mm gap from the worktop
  3. Mat UK
    London, UK
    Plan of attack?
    My first step is to true up and flatten the face where the corner stands proud.
    1. Using double sided carpet tape I stick the blank to my flat worktop (18mm mdf) and
    2. Fashion a router thicknessing base out of mdf offcuts. This is cheap and crude but does the job. I can't remember the measurements, but in essence it's 25mm length of mdf with a hole drilled in the middle and mdf rails glued to the base on both edges - complex stuff. I've got two of these for different depths of cut.
  4. Mat UK
    London, UK
    Oh yeah, I wedge the raised corner with a small bit of scrap... This prevents flex when cutting
  5. Mat UK
    London, UK
    Power up and trim
  6. Mat UK
    London, UK
    And the thickness?
    So the resulting thickness is about 9mm reducing to 5mm in the corner - actually it's more like 4mm, I took off another 1mm.
  7. Mat UK
    London, UK
    That's it for my morning pre-work 45minutes.
    Tomorrow I'll sand out the routing marks and then think about truing the other face
    I told you it was tedious!
  8. Davecam48
    Queensland Australia
    So what's the problem with meranti? I have made at least 3 necks using "meranti" from my local go to hardware and timber supplier and they are all still quite OK no signs of any bowing/twisting etc. However I have seen lots of different timbers which are referred to as Meranti. and they guys where I buy it say the actual species supplied as Meranti varies a lot.
    I try to get dark straight grain boards and find it works and finishes easily.
    DC
  9. guitarbuilder
    Now you've done it.....what's next pine? :)
  10. Mat UK
    London, UK
    The meranti I picked up was a mid/light red colour (which are supposed o have similar properties as pine) - so probably not as strong as the darker varieties - that was reflected in the price though I guess.
    Guitarbuilder directed me to one of your threads but I couldn't find any finished pics; would you mind posting some pics? I'd be mightily interested! Particularly to compare how you wood looks to mine...
    I challenge anyone to say a Balsa wood neck is undoable ;-)
  11. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    That's a great way of getting rid of a twist or bow. I have a few pieces that need the same treatment but I have a thickness planer and that's the recommended way. Run it through on something flat and wedge it so it doesn't move.
    Balsa wood? No neck dive there...
  12. Mat UK
    London, UK
    A thickness planer?... That's just cheating! Workshop tools are a step above what I have to work with, I'm still accumulating hand tools.
  13. trev333
    Coolum Beach,Australia
    We use a lot of meranti as skirting boards, window/door trimming..that sort of thing....
    more like a mahogany texture than pine....
  14. Mat UK
    London, UK
    Sorry, I meant in terms of strength/hardness/flex
    You haven't been tempted to try it for a neck?
  15. Davecam48
  16. RickyRicardo
    Calgary, Alberta
    But you have a router... What more do you need??? :lol:
  17. Mat UK
    London, UK
    Thanks Dave - that's one of the threads I looked at before buying the timber.
    "The next build will be a bit radical, a bit different, and very ugly, but hopefully will play ok. Ugly is OK ............I've been putting up with it all my life!"
    In other news - any progress on this build? Sounds intriguing...
    True, insert a tooth brush head into the chuck and you've got yourself a nifty electric toothbrush - the challenge is keeping the toothpaste on
  18. Dasher
    Dasher Tele-Meister
    Sydney, Australia
    Hi Matt, I've made necks with Meranti without problems. However, what I did was wedge it between two pieces of Tassie Oak in a three piece laminated neck.
  19. Mat UK
    London, UK
    Thanks Dasher - that's good to know; I've got enough meranti for a couple of necks so I could well test that out, I'll just have to figure out how to turn my router into a jointer!
  20. Mat UK
    London, UK
    Trued up the other face this morning - same process as yesterday...
    It's revealed some lighter streaks; I'm not sure how I feel about it yet!
