Another incoming build
Discussion in 'Shock Brother's DIY Amps' started by allesz, Mar 23, 2020.
  1. allesz
    allesz Tele-Holic
    Italy - Bologna
    In my parts bin I have left a couple of transformers: PT 160-0-160 and 6,3V 4A secondary (it should be good for an amp with a quartet of el84) and OT Single ended 6600 Ohm into 4 or 8 Ohm 15 watts.
    I would like to build 6L6 single ended bass amp for a friend, but the voltage the PT puts out is too low.
    Would it be possible to use a full silicon rectifier and voltage doubler to get around 400V for the power tube? Can you point me to a schematic?
    Then, since this will be a bass amp, I am thinking about the pre... I don't want to add a lot of knobs, so I wonder if a baxandall eq and just a volume control would work.
  2. Badside
    Badside Tele-Meister
    Montreal, Qc, Canada
    If you ignore the center tap and treat it as a 0-320, a bridge rectifier will net you around 450V. BUT it will cut the current handling in half.
    What's the current handling on that thing? Low voltage high current PTs are typically are to find
    sds1 likes this.
  3. allesz
    allesz Tele-Holic
    Italy - Bologna
    It should be around 200 mA, it was advertised has an AC30 replacement PT... not sure if it's correct; it's a toroidal transformer, so it is difficult to compare the dimensions with standard trannies.
    Please, show me the way to hook the tabs in 0 - 320 configuration.
  4. tubegeek
    tubegeek Tele-Afflicted
    Brooklyn, NY
    If you can identify the 160-0-160 terminals, ignore the 0 and use 160 and 160.
  5. allesz
    allesz Tele-Holic
    Italy - Bologna
    Dho!
    Thank you, I feel very dumb... but now I have the parts!
  6. Mr Ridesglide
    Mr Ridesglide Friend of Leo's Silver Supporter
    Bloomington, MN
  7. allesz
    allesz Tele-Holic
    Italy - Bologna
    Thank you, I just saved the schematic of the doubler.
