Another Blacktop Thread
Discussion in 'Telecaster Discussion Forum' started by AxeVictimAZ, Aug 8, 2020.
  1. AxeVictimAZ
    AxeVictimAZ Tele-Holic
    Arizona
    Has anyone here modded their Tele Blacktop and then reverted it back to stock?
  2. steadyriot
    steadyriot Tele-Meister
    Netherlands
    I modded mine, but didn't go back. Don't see a reason why you would want to go back to those original humbuckers to be honest. Dull and lifeless.
    AxeVictimAZ likes this.
  3. Rich_S
    Rich_S Friend of Leo's Silver Supporter
    Potsdam, NY
    What sort of mods are we talking, here? It's pretty general term.
    Obviously, if your "mod" is to add a monkey grip ala' Steve Vai, then returning the guitar to stock might be a bit of trouble. If you're just talking pickups, people swap those around all the time.
    If you're talking about modding a Blacktop back to being a normal Tele with a single coil mounted in the bridge, stop right there. Once a Tele is routed for a humbucker, there's no going back. Humbucker routes are wider than standard Tele bridge plates. I learned that lesson the hard way many years (and Teles) ago.
  4. Ess Eff
    Ess Eff Tele-Holic
    Yeah, those pups are awefull imo.
    I've modded 2 Strat blacktops. You can pick them up second hand real cheap n they have the best necks.
  5. bigben55
    bigben55 Friend of Leo's
    Cincinnati, OH
    Heres mine and what all ive done to it:
    SD 59s(bridge is F Spaced)
    New pickguard
    Graph tech String Saver saddles
    Kinman style treble bleed
    Bridge coil tap
    Alpha pots
    Orange Drop .022 tone cap
    New dome 20200506_152729.jpg knobs
    navigate40, scook and AxeVictimAZ like this.
  6. Beachbum
    Beachbum Friend of Leo's
    Sand Land
    MIM modded with 83 Fullerton Strat neck and OV 52 pickups.
    And back again. Kept the pickups though.
  7. AxeVictimAZ
    Arizona
    Yeah, nothing crazy like the monkey grip you refer to. A long time back I swapped the pickups out for TV Jones Classic in the neck and Classic+ in the bridge. Was recently noticing it was kind of spiky Or ice picky if you prefer. I DID roll off the tone but it was still not what I was wanting. I thought about trying some other types of humbuckers but ended up finding a spec for th e recommended height. I checked mine and they were very high. I moved them down to the 6mm for neck and 5mm for bridge. What a difference that made. I also know but this reminded me that I need to work on my technique. I play too hard. Always have. If I lighten up my attack, that too plays a big part on the tone.
  8. teleaddicted
    teleaddicted Tele-Holic
    Roma Urbe
    heffus and AxeVictimAZ like this.
  9. scook
    scook Tele-Meister Silver Supporter
    Etlan VA
    I actually have a stock one that I can’t wait until I get the time to change out the pickups
  10. AxeVictimAZ
    Arizona
    How do you like those Graph tech saddles?
  11. bigben55
    Cincinnati, OH
    I personally love the Graph Tech saddles.....on the right guitar. They do rob some treble; they impart a warmer sound. I wouldn't put them on a traditional tele bridgeplate; brass is better for that. Compared to the stock bent metal Fender strat saddles it came with, they definitely add a touch of sustain. I have them on my G&L Legacy too. They hold up; they've been been on that one for 20 years. Obviously, they completely eliminate string breakage at the saddle. I like them.
  12. Rich_S
    Potsdam, NY
    I don't have a Blacktop, but I do have a double-humbucker "Tele"; mine is a goldtop Schecter PT body with a maple MIM neck. It's a tribute to Pete Townsend's "Live Aid" guitar and a replacement for the real-deal all-black PT I owned in the '80s.
    I'll second bigben55's choice of the Duncan 59 set in a Tele, they're great. My setup is similar to his: 4-wire 59B with a coil-split pull-pot and a 59N in the neck, but I don't bother to split it. I love the fat, woofy 59N sound. I have a phase-reverse switch on the neck volume pot. Yes, it's two volume controls and no tone. I never use tone pots, but I love the ability to blend the two pickups in middle position. I find this setup gives me a lot of the options, but with just two pots and a switch.
    AxeVictimAZ and bigben55 like this.
  13. navigate40
    navigate40 Tele-Meister
    SE FL
    I think it is one of the best modding platforms out there. I have had two and just modded the heck out of both. Have done SD Phat cats, Phat cat/SC, two HB's. Added a bigsby.
    Here is a pic of one, Seafoam Pearl (amazing color). Phat cat bridge, Fralin blues strat SC neck, bigsby (Vibramate mount):
    Current configuration is twin Phat Cats, since I have HB and SC guitars.
    AxeVictimAZ and scook like this.
  14. bigben55
    Cincinnati, OH
    I had the 59n lying around, a 2 wire, so I used it. I ordered the 59 bridge. Ive never really liked split humbuckers, especially neck humbuckers so I didn't worry about it. The bridge I split so I could get some semblance of twang when needed. A light boost helps, and it does twang some split but not majorly. The 59n sounds great fill vol, but i prefer the Jazz neck as soon as you start rolling off gtr vol. If i had to buy a tele neck humbucker, it'd be a Jazz, and I probably still wouldn't split it.
    navigate40 and AxeVictimAZ like this.
  15. AxeVictimAZ
    Arizona
    I replaced the stock saddles with something else a long time ago but don’t remember what they are. I’ve got some cranky noise going on with my first string (not nut or fret) but maybe that kind of saddle would calm that down.
    Is that a Blacktop? I love that color but that was not a stock color for them. Did you paint it? It looks great.
  16. Rich_S
    Potsdam, NY
    Yeah, the 59B split is not the greatest single-coil sound in the world, but it's passable. On the rare occasions I gig, I take the goldtop for humbucker sounds, and my regular Tele for Tele sounds. In the event of a broken string (or more serious catastrophe) or sometimes just to reduce guitar-swapping within a set, I'll split the 59B to make it a "close-enough" substitute for the "real" Tele.
  17. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Modded ... still.
    I bought it used with some 'metal' SD pickup and standard control plate orientation.
    I yanked the SD out and put my own in, reversed the plate, added a 4-way switch to control both bobbins individually plus parallel and series humbucker.
    Awesome chunky neck.
  18. navigate40
    SE FL
    Axe - the guitar was a stock Fender FSR HH tele. I don't recall if it was called a blacktop, per se.
    The color, Seafoam Pearl, is a Fender color and finish. Stunning. It may be an FSR color, I don't know. A friend HAD to have it so....sold it to him.
    My current HH tele is a custom made, pine body one. But, I would not hesitate at all to jump on a Fender HH tele. As I wrote above, the perfect mod platform. You can put any pup or combination of pups in (P90's, if you chose HB sized ones).
    I am not sure, however, Fender may produce blacktop models AND HH models. Basically the same thing, but blacktop models must get their blacktop pickups...which are nothing special...generic BHK pickups.
    One note: BHK pickups can sound MUCH better, with the covers off.
    And...new models *may* have HB's with alnico V magnets (rather than the cheap ceramic one's of earlier models)
    Hope this helps
