Another amp blowing fuses... but why?
Discussion in 'Amp Tech Center' started by MrCoolGuy, Jul 10, 2020.
  1. MrCoolGuy
    MrCoolGuy Tele-Meister Silver Supporter
    Fort Worth, TX
    They connect here. You think this orange cap could have failed?
  2. MrCoolGuy
    Fort Worth, TX
    Holy ****. That was it!
    Asmith and hepular like this.
  3. MrCoolGuy
    Fort Worth, TX
    Dude... this amp has been killing me!
    I should have known to check that cap.... you led me right to it (several people probably did and I just didn't realise). Honestly, had it been an electrolytic cap, I would have caught it day one. But these sprague orange drops... I thought it would be fine.
    Thank you, Asmith, Jhundt, Tubegeek, etc.
    hepular and tubegeek like this.
  4. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    I love the smell of victory!
    hepular and MrCoolGuy like this.
  5. MrCoolGuy
    Fort Worth, TX
    The culprit. Failed open. (Correction: short)
    1.1 ohm resistance...
    OL capacitance...
    Thanks again, everyone.
    Learned a thing or two on this one.
    King Fan, hepular and tubegeek like this.
  6. tubegeek
    Brooklyn, NY
    Failed SHORT. Open wouldn't have caused a problem. I think it's only there to quell the 'pop' of the standby switch? I think?
  7. D'tar
    D'tar Friend of Leo's
    WNY
    Assume nothing! Suspect everything!
    Next time you will find it in 10 minutes!!!
    Good job
    tubelectron likes this.
  8. tubelectron
    tubelectron Tele-Afflicted
    France
    Fine @MrCoolGuy ! :cool::)
    It was a short, indeed. The problem was to locate where it occured... Without having the amp on my bench for vision and testing, it's always more difficult to direct at distance... ;)
    But as @D'tar mentions :
    -tbln
    D'tar likes this.
  9. MrCoolGuy
    Fort Worth, TX
    Indeed, short. Thanks again everyone!
  10. tubelectron
    France
    I personally place that anti-click capacitor directly accross the 2 terminals of the SBY SW, not vs. GND. I choose a 630VDC 0.1µF and it's fine to make the switching competely silent.
    But it's me, OK ? :D
    -tbln
    tubegeek likes this.
  11. tubegeek
    Brooklyn, NY
    But if it failed short YOUR way the standby switch wouldn't work! Instead, with the stock setup you might take out the power transformer and the amp is totally dead.
    What kind of tradeoff is THAT? ;)
  12. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    I would have said Eureka personally but that does the job just fine. :D I'm glad I guided you to the source, now make some noise!
    Follow up question: The cap isn't on the posted schematic, correct?
    MrCoolGuy likes this.
  13. MrCoolGuy
    Fort Worth, TX
    Not on the one I was using. I kept going over that schematic and pulling things in that line... I looked at it a hundred times, I don't know what I was thinking.
    But thanks again.
    Asmith likes this.
  14. MrCoolGuy
    Fort Worth, TX
    Question... how is what this cap did "open"...
    A short circuit implies that the two terminals are externally connected with resistance R=0 , the same as an ideal wire. This means there is zero voltage difference for any current value. ... An open circuit implies that the two terminals are points are externally disconnected, which is equivalent to a resistance R=∞
  15. MrCoolGuy
    Fort Worth, TX
    Oh I'm retarded sorry. I thought I wrote it ther other way. Nevermind! Lol
    I need rest.
    tubegeek and hepular like this.
  16. tubelectron
    France
    Well, I do this on all the amps that I built on which I have a SBY switch or any HV switching. I never had any issue with that switch shunt capacitor solution and indeed the treated switches by this method are absolutely quiet and klik-free...
    Here's an example on my last one - The Serial Tone Killer :
    That said, I really invented nothing here : it was (and still is) extensively used on tramways, trolleybuses, circuit-breakers, any electric motor or contact prone to generate arcing and RF noises... ;)
    -tbln
  17. tubegeek
    Brooklyn, NY
    I dunno, I'm still leaning towards the potential-PT-damage method, @tubelectron .
  18. MrCoolGuy
    Fort Worth, TX
    Yeah... who needs a PT?
  19. tubegeek
    Brooklyn, NY
    Exactly! They're heavy, expensive....
  20. King Fan
    Salt Lake City
    Yes, and that would end the constant stream of "which PT?" threads and "wrong PT" comments...
    MrCoolGuy and tubegeek like this.
