Another amp blowing fuses... but why?
Discussion in 'Amp Tech Center' started by MrCoolGuy, Jul 10, 2020.
  1. tubelectron
    tubelectron Tele-Afflicted
    France
    Well no, @tubegeek : why the PT would be more endangered that way ? It would rather be the opposite situation :
    1 - if the SBY SW is open and the shunt cap proves to be defective o_O, then at worse your are in the situation of a "permanently closed" SBY switch. No possible short. Your SBY switch malfunctions because of the leaky/shorted cap across his terminals, but that'all. So you replace the defective cap and voilà... :cool:
    2 - most of the time, you play your amp, right ? :lol: So the SBY SW is closed, then shorting the capacitor itself, which de facto has no more voltage accros his terminals... :cool:
    I hope I'm clear in my description... :oops::rolleyes: I apologise in advance ! ;)
    -tbln
    tubegeek likes this.
  2. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    I'm saying the OP's setup makes him liable to get a short on the power trans (just as it did). Ultimately possible PT damage.
    The way you have it is AOK.
    I was being sarcastic.
  3. tubelectron
    France
    Ah, sorry @tubegeek : I always miss some subtleties of english language... o_O:D
    -tbln
  4. tubegeek
    Brooklyn, NY
    Sarcasm fails about 20% of the time via written comms.
    As a chronically sarcastic person I am well used to backtracking.
    Is Français your native language? You do just fine in English.
  5. tubelectron
    France
    Well, thanks ! :)
    Yes, French, absolument. I try to maintain a reasonable training to English language - at least in writing / reading - since I do not work anymore in export... Not easy ! :confused:
    -tbln.
  6. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    so the problem was this cap which doesn't show on the schematic drawing?
    and the purpose of this cap is to make the standby switch function 'better'?
    there's a good reason to not add a standby switch and a bunch of 'improvements' to a good old simple circuit.
    glad you finally got it sorted!
  7. jhundt
    Netherlands
    It was right there, on this schematic; but I kept looking at the other one, and missed it. If we all had been referring to this drawing someone would have spotted it earlier, I guess.
    http://www.lynx.net/~jc/sobSchm.gif
    D'tar likes this.
  8. tubegeek
    Brooklyn, NY
    That's the one I had been looking at! But I was expecting to see the two-caps-plus-two-resistors cluster and I just didn't see it in the pics.
    jhundt likes this.
  9. D'tar
    D'tar Friend of Leo's
    WNY
    Well shoot ! No wonder it failed..... It's only 60.volt!!!:)
    King Fan, Asmith and jhundt like this.
  10. jhundt
    Netherlands
    yes; I am so used to seeing a schematic laid out in a certain way, this one tricked me. It is a lesson for us, I guess.
  11. tubegeek
    Brooklyn, NY
    That's not it. That's the cap that was supposed to have B+ on it. 47uF 600V.
    Look on the other side of the standby switch, the two cap two resistor combo to ground. They mustv'e swapped in the single cap (which failed) as a production change/random decision/repairman's kludge.
    (The line & box symbol is Euro for 'electrolytic cap.')
    hepular likes this.
  12. D'tar
    WNY
    If those(both) failed the fuse would blow even in standby.
    Any way... I was just playing... It looks like they wrote 60.v but it's actually 600v
    King Fan and tubegeek like this.
  13. tubegeek
    Brooklyn, NY
    Wow. You're right!
    How come the amp in the thread didn't I wonder? The shorted cap must've been on the Node D side of the switch, in parallel with 47uF 600V.
    Therefore its only purpose was to provide a failure mode, and it did its job perfectly.
    SMH. Someone screwed up bigtime.
  14. MrCoolGuy
    MrCoolGuy Tele-Meister Silver Supporter
    Fort Worth, TX
    No, those two caps and resistors are there too. This is an additional cap. For stand-by pop. They just mounted it at the intersection of stand-by, choke and OT instead of on the stand-by switch.
    It is that 47mf/600v cap shown on this other schematic. Just didn't think of it. Brain fart.
  15. tubegeek
    Brooklyn, NY
    That brown turd cap is many things, but 47uF/600V is NOT one of them.
  16. D'tar
    WNY
    nF
  17. King Fan
    Salt Lake City
    Poll. Which of the following is *most* prone to cause user error?
    1. uF, nF, pF
    2. Ohms, K, M
    3. Color bands on resistors, allowing for 4 vs. 5 bands
    4. Tiny, oddly labeled settings on DMM dials
    5. The 1mm-tall 'K' or 'M' hiding next to the 1-inch-tall (often decimal) reading on DMMs
    jhundt and D'tar like this.
  18. D'tar
    WNY
    Um,
    I choose, number 1
    No, 3
    Maybe 5 or is it 4
    No,no, 2 for sure!
    Ahh..... 6 it is!
    King Fan and Asmith like this.
  19. MrCoolGuy
    Fort Worth, TX
    My bad... .047 uf / 600v.
  20. MrCoolGuy
    Fort Worth, TX
    6. Microscopic print on diodes and small caps.
