buckwalder
Someone may have already mentioned a similar method but I searched and was unable to find it, if it exist.
All you need is these three things.
1. sharpened pencil.
2. A 1/2 or 12 mm socket with a 1/2" drive.
3. A pair of vice grips.
First you want to secure the 1/2 or 2mm socket with your vice grips as high on the socket as possible so you don't scratch your tele. Remove vice grips from socket for now.
Poke the sharp end of the pencil through the hole of the socket into the input jack. If the pencil has an eraser,you should remove it.
Tap on the end of the pencil hard enough so that the wood of the pencil distorts and grabs onto the inside of the jack.
Take your vice grips and secure them to the 1/2 or 12mm socket.
Tighten the nut.
By the way I know about the Electrosocket. This little trick is something I have done to many teles through the years.
You can add fingernail polish or blue Locktite if you feel the need.
Hope you guys find this helpful.
Tighten the nut.
