Amps with stereo chorus similar to a JC
Discussion in 'Amp Central Station' started by ftbtx, Dec 12, 2019.
  1. mistermikev
    mistermikev Tele-Holic
    phoenix
    semantics but pretty sure jc was never "true stereo". what passes for stereo chorus is actually just a mono chorus signal and a mono dry signal. you can get that by running two amps and one of them with a chorus in front, one dry. Many of the variants of the analog chorus offer a second mono out for accomplishing just that.
    tintag27 and ftbtx like this.
  2. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    :):)Really ? to be honest i've never seen one of them in person, maybe once, but i've been very close to buy one a couple of times, in some way they attract me.
    Here in Italy in the late 80's early 90's the Fender Red Knob series was almost everywhere....;);)
    ftbtx likes this.
  3. aux8
    aux8 Tele-Meister
    Ireland
    Yamaha THR10c is a stereo amp that excels at bedroom levels and has nice chorus built in.
    ftbtx and stealyerface like this.
  4. stealyerface
    stealyerface Tele-Afflicted
    Upstate NY
    This thing is my new favorite toy... Plus, if you go onto the Yamaha Owners Forum, there are guys that have entire their entire libraries of custom presets that you can download, and instantly access.
    ~syf
    ftbtx likes this.
  5. control voltage
    control voltage TDPRI Member
    3rd from the Sun
    The Ampeg VH-140C and SS-140C have a lush chorus sound, and can also produce useable distorted sounds, whereas people don't seem to like the distortion on the JC amps. The Ampegs have separate preamp gain and volume controls for each channel. They have a little bit of a following, so they're probably going to be priced at $300 US or more.
    I recently bought a Crate GX-140C for $50 US, and it's pretty similar, though a little smaller and lighter. It doesn't have the low-end oomph of the Ampeg, but I think it sounds pretty good. The reverb isn't footswitchable, though, like it is on the Ampegs. Crate made several similar models to this, both combos and heads, and they seem to be available for very low prices. Like the Ampeg, it can go from very clean to very metal.
    These photos are from the internet. I couldn't find a very good picture of this specific Crate model:
    ftbtx likes this.
  6. control voltage
    3rd from the Sun
    Another one, along similar lines to the two above, is the Peavey Stereo Chorus 212. A friend had one, and I thought it sounded good. They made a Classic Chorus 212 and Studio Chorus 210 also, but I haven't had any experience with those.
    Photos from the internet:
    neilybob100 likes this.
  7. neilybob100
    neilybob100 Tele-Meister
    These are my 2x12 combo's[​IMG][​IMG]
    Sent from my CLT-L29 using Tapatalk
  8. Ex-riverman
    Ex-riverman Tele-Holic
    Tulsa, OK
    I think a JC is the right choice. They sound fine at low levels and have a headphone output. And they are a true stereo amp with L and R inputs and outputs. I have a JC 22 but if I were wanting to play with others I’d get the JC 40.
    ftbtx and ScribbleSomething like this.
  9. knockeduptele
    knockeduptele Tele-Holic
    London
    ftbtx likes this.
  10. Addnine
    Addnine TDPRI Member
    New England
    I have had a Fender Ultimate Chorus for years. I don't use it much. They can be found quite cheap. (Mine can be found in the basement.) They weigh approximately 400 pounds.
    The chorus is so ridiculously lush it will put you to sleep. Yes, it has two discreet power amps and is legitimately stereo.
    They are remarkably loud and have a pretty but sort of watery clean. Not a lot of harmonics, with maybe a little solid state hifi quality ... but very pretty.
    For some reason, loud as they seem, they do not stand out in the mix, even turned up beyond reason. They just become a very pretty looming presence, looming away,more or less musically. I guess they might be the world's loudest practice amp, or the perfect amp for playing that smirpy song from Titanic.
    The overdrive (clipping) is so wretchedly buzzfest awful that it is toxic. I think I read once that it actually killed a guy right there in his garage, banging out covers of Mantovani favorites in the manner of Limp Bizzkit.
    It does sound pretty, if that's what you want, annoyingly so.
    ftbtx likes this.
  11. schmee
  12. schmee
    It is interesting how many 80s-90s amps dont cut through. The Music Man's I had were that way. Even the 100 watter! It had been to a tech and said it was putting out 92 watts. In a big hall I couldn't hear it well in the band mix. Changed to my BFDR at break and everything was fine! I think they are made with huge mid scoop like so many of those 80's songs. Hollow sounding, big bottom and big top.
  13. knockeduptele
    London
    yip fits the inserts - basically a 10k pot and a couple of jack plugs but a very neat solution - also allows me to use an Ultimate Chorus which is 4 times the power of the Princeton in the workshop
  14. ScribbleSomething
    ScribbleSomething Tele-Holic
    San Antonio
    I have a JC 40 it can get plenty quite or loud depending on your need — especially if you also use the volume on the guitar.
    The new distortion is serviceable if it’s all you got. I have to turn down the treble as i turn up the gain.
    Personally I’m looking at the new Boss Waza headphone amp. It seems pretty great but also pretty expensive.
    ftbtx likes this.
  15. bettyseldest
    bettyseldest Friend of Leo's
    I have had a late 80's Peavey Studio Chorus 70 since the early 90's. 2 x 35w stereo into 2 x 8" speakers. Fairly compact, with a nice clean sound, still use it as a backup. They still come up occassionally in the UK, last I saw in the UK was under £40 without a footswitch. Footswitch is 7 pin DIN connector controlling channel selection, reverb and chorus.
    EDIT: I have just checked the manual, and the DI out on channel 1 has chorus, and channel 2 is dry. So a stereo amp, but not strictly stereo chorus.
    ftbtx and neilybob100 like this.
  16. Eastbound71
    Eastbound71 TDPRI Member
    Pennsylvania
    Oh man I didn’t know these peavey studio chorus 70 amps existed. Can you comment on the weight of this amp..I’m really into these older peaveys right now
  17. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Meiners Oaks CA.
  18. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    The original post was about finding a chorus amp that had a good clean sound at low volume. They all do, unless it's a crappy amp, full stop.
    ftbtx likes this.
  19. ftbtx
    ftbtx Tele-Afflicted Ad Free Member
    The west side of Texas
    Hi all, I went with the JC40, thanks for all the help!
    BigDaddyLH and ScribbleSomething like this.
  20. bettyseldest
    With the footswitch and a guitar cable tucked in the back mine just came in at 28 lbs on the bathroom scales.
