Amps with stereo chorus similar to a JC
Discussion in 'Amp Central Station' started by ftbtx, Dec 12, 2019.
  1. ftbtx
    ftbtx Tele-Afflicted Ad Free Member
    The west side of Texas
    Hello all,
    I am looking for an amp with a master volume, so I can play at bedroom levels, that has a stereo chorus similar to the Jazz Chorus. I know about the smaller JCs, but I don't believe they have a master volume and may still be too powerful to get good tones without pissing everyone off.
    Any inputs are welcome, or even pedals, etc. I will mostly be using the amp as a clean platform for modelers and pedals.
    Many thanks!
    FTB
    edit: I'd prefer a 2x10 or 2x12
  2. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    Try with this.
    https://www.thomann.de/it/blackstar_blackstar_id_core_100.htm
    ftbtx likes this.
  3. ftbtx
  4. Thin white duke
    italy
  5. Thin white duke
    italy
    You're welcome, i' ve posted another one...
    ftbtx likes this.
  6. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    Have you tried JCs at low volume? They sound good to me. My current favourite is the 2x10 JC-40.
  7. mistermikev
    mistermikev Tele-Holic
    phoenix
    the jc chorus is available as a pedal... ce-1/ce-2 or really any mn2007 based analog chorus will get you there. just a thought.
    ftbtx likes this.
  8. ftbtx
    I'll give it a try. You have no problem getting good tone at low levels?
  9. schmee
    The old Fender Princeton Chorus SS amp 2 x 10 isn't bad at all really. Only 25 watts per side I think. maybe $150-$175 used.
    SheldonP, Deaf Eddie and ftbtx like this.
  10. BigDaddyLH
    No. I don't have a JC now, but I had a JC-120 back in the day, and I've checked out the JC-40 when it came out.
    They are clean, SS amps. I usually don't see any problem turning an amp like that down.
    As for simulating one with a pedal, one of the special things about the JC is that it is a stereo amp. The dry signal comes out one speaker and the chorused signal comes out the other.
    tintag27, Deaf Eddie and ftbtx like this.
  11. Eastbound71
    Eastbound71 TDPRI Member
    Pennsylvania
    How about a peavey studio chorus 210. It will give good tones at low volumes. My other choice would be the Princeton chorus.
  12. radiocaster
    europe
    Gallien Krueger had some in the 80s/90s. Not sure you'd want the combo versions, they had 6.5" or 8" speakers. Look them up yourself.
    That Cal Webway and ftbtx like this.
  13. stealyerface
    stealyerface Tele-Afflicted
    Upstate NY
    I've got a JC-77 that I can peel wallpaper off the wall with, or I can temper down and get pretty decent tone.
    One thing I have done in the past, is plug into the "Low" input jack. I believe it was originally made for keyboards, but I can turn the guitar volume up, and keep the levels acceptable to house-level.
    If you can find one of those, even thought they are still pretty heave, way easier to cart around than the 120, and the best chorus of their generation for sure.
    ~syf
    ftbtx likes this.
  14. Thin white duke
    italy
    You mean this right ?
    tintag27, That Cal Webway and ftbtx like this.
  15. Jerry J
    Jerry J Tele-Afflicted
    NoVa
    ^^^^ may be your cheapest option. I personally have a Retro-Sonic Chorus based on the CE-1
    ftbtx likes this.
  16. Peegoo
    Peegoo Tele-Holic
    but the OP wants true stereo from one amp.
    ftbtx likes this.
  17. radiocaster
    europe
    That's one of them, but they also had a later model.
    ftbtx and Thin white duke like this.
  18. Guitarteach
    :). Memories...
    There was barely a london theatre pit in the late 80’s/early 90’s where that wasn’t the go to amp.
  19. BigDaddyLH
    If weight is a consideration:
    JC-120 = 62lb, 2x12"
    JC-40 = 35lb, 2x10"
    ftbtx likes this.
  20. EsquireBoy
    EsquireBoy Tele-Holic
    Paris, France
    Because JC amps are all about clean tones, and since they are transistor amps, I really do not see the point of a master volume. They sound pretty much the same at lower and higher volumes (minus the speaker pushing some air, but you cannot have that with anything except volume anyway).
    I played on a JC40 last week, and the taper of the volume pot makes it easy to dial a real bedroom volume.
    ScribbleSomething and ftbtx like this.
