@Lowerleftcoast : I'm afraid you've lost me a bit in your last paragraph.
The "glaring problem" with the "way hot triode" is, I think not such a problem as you may believe. If you look at the schematic and the voltage chart I posted from the service manual, it becomes clear that pins 1/2/3 are the "V1b", side of that tube; not the first stage, but the tremolo. The voltage chart from the service manual says that pins 2 & 3 have voltages 310 and 6.2 V when the trem is off, and 100 and 0.8 V when it's enabled. So, while the voltages from the Verberwaffe R-12-R clone vary from that a bit, they're not out of the ballpark. The input stage is pins 4/5/6. Those voltages reported for the Verberwaffe are right on the money, agreeing well with those in the service manual for that triode.
All the other preamp tubes have the "a" side as 1/2/3, and the "b" side as 4/5/6. I don't really know why the first 6SN7 is different, but it is -- this reminds me of that conversation hereabouts recently having to do with the "b" side of a double triode (at least in the 12A*7 world) being "preferred" for hum (or the lessening thereof). Because I found this confusing while doing my version of the schematic, I actually marked up the service manual voltage chart to indicate the V*a or V*b correspondence. And both schematics (Ampeg's and mine) have the pin numbers on the tube diagrams.
Now, I'll have to go back to Blencowe's Preamp book to figure out what your comments about the MPD mean.
