Over the years that I have been interested in this field of guitar amp circuits, I've developed a particular interest in the Ampeg Reverberocket R-12-R, a push-pull 6V6-powered design from the early '60s with an all-octal preamp tube complement, reverb, tremolo and a paraphase PI. It's way more complicated/complex than my building/troubleshooting skill set now, but I can't help myself from researching it, even though most of the amps I'm interested in are of the Fender Tweed persuasion.
During COVID, I've continued this research, and I've lately found myself thinking that I should do a project schematic for it, and start working on a layout. And here's the state of my brain: I found out last week that I had already done the schematic in CAD, during a month of 2020's winter COVID surge and the political angst and turmoil of the election -- and I'd completely forgotten about it! Really -- I have no memories of the process at all.
Since I lately tagged a year-and-a-half old thread I had started, based on some recent research, which resulted in some "likes", and mentioned this schematic which resulted in a request to see it -- here it is, along with the Ampeg schematic I have worked from, and also an Ampeg service manual that I found.
There were several iterations of the R-12-R (that is R-12 with [trem and?] reverb), starting with the octal preamp / 6V6 one presented here, and progressing through ones using 7591 or other power tubes, and even later preamp using 12A*7 tubes and more exotic compactrons, and so forth. I believe that Everett Hull kept trying to make the amp into a jazz/clean thing, which was his personal bent. But the ones that a lot of people seem to have a fondness or regard for are the ones at the starting point, like this one.
In a way I'm quite lucky to have found (in different locations) a schematic (from the Hoffman EL34World archives) that somebody marked up with the component numbers, and also the service manual that seems to be consistent with that schematic in every respect, (except an un-numbered resistor) and contains baseline voltages and resistances for the circuit, plus a lot of specs for the hardware.
{see attachments below}
I have done some modifications in my version of the schematic which are listed on the right hand side. I've also included, on the same PDF, the Ampeg schematic in question. And I added to the service manual the same schematic (again) and have annotated things in the service manual that reflect my research. I've also appended a page that has some of the research info, and a couple more about reverb tank characteristics. Obviously this is a work in progress, still. I have yet to double-check my own work, and I'm not asking anyone else to do that -- though I would of course appreciate knowing about any stupid errors you may find.
As for layout, there are some resources for this by people who've
1) owns or owned one (1961) and documented it (Troy D. Woods) https://www.pdf-archive.com/2016/05/30/ampeg-r12r
2) built a clone ("Sonny ReVerb" in thread Ampeg R12-R Reverberocket variant on Hoffman's site EL34world.com https://el34world.com/Forum/index.php?topic=22267.0
3) Hoffman also has a "layout" in his Schematics hierarchy that's just a circuit board with off-board destinations for terminals https://el34world.com/charts/Schematics/files/Ampeg/Ampeg_r_12_r_layout_rev_a.pdf
Links for these currently work, though if you ask I can provide what's at these locations. I also have a trove of photos of various R-12-R amps that I've scarfed from google searches, which I could upload to a DropBox or OneDrive location -- though the organization of it is not stellar. However, most of it has filenames that are fairly descriptive.
Regarding layouts: I have an aversion to the Vox-like arrays of parallel or nearly parallel components, with sheafs of conductors running parallel to the long edges of the board(s). To me, a Fender-style layout makes a lot more sense, as in #2 above (though I have not delved into it enough to know whether all the components are there -- looks a bit sparse on first glance). So that's what I would prefer to do. I should look at Fender layouts that have both reverb and tremolo, to see how those portions of the circuit are handled, though the trem shares a tube with the first preamp stage in this case, which has a certain inherent gravity to it.
I'm inclined to build a head, rather than a complete combo, partly because the octal preamp tubes are reputed to be more microphonic (I assume that some isolation from speaker vibrations would help with that), and partly because I just don't have room for a bunch of combos.
As always, comments welcome!
