After working on my friends Ampeg G12, I thought about trying to make a small, no frills, single ended practice amp in the same "spirit". As far as I know, most Ampeg stuff is push pull, so I took the power section from a Tweed Princeton, and did a few tweaks. As for the Ampeg preamp part, I kept the same value Grid and plate resistors, and Coupling capacitor values. I couldn't do a Baxin/James tone stack, so instead I put a Mid control after the second triode. (not the Framus mid control, but not far off.) No inverse feedback. I also had to go down to 500k volume pot because 1 meg oscillated at full volume.
This is a quick video I just did. I started in the "Accordion" input. When I went to the guitar input, it was a little crackly, I'm not sure if it's the dirty power in my house (same outlet as my boiler and pumps) or something to look into. I'll move it to another outlet and check later. Let me know what you think! (Comments for the amp, Not the open G playing, I know that needs work.)
