Amp With No Knobs?
Discussion in 'Shock Brother's DIY Amps' started by The Ballzz, Jan 19, 2021.
  1. RockerDuck
    RockerDuck Friend of Leo's
    Canton,GA
    MReynolds likes this.
  2. enorbet2
    enorbet2 TDPRI Member
    Viurginia, USA
    Joe Walsh once asked me why amp builders couldn't build amps "with just a big Louder knob" and I replied "I could, but you would need one for each guitar". I thought about that for a long while and decided to at least get close but make it at least possible to dial in for different guitars, even acoustic-electrics. So I gutted an old Silvertone amp that basically started as a Champ clone but with a 10" speaker, added another preamp tube socket, beefed up the power supply and converted the output to a single-ended EL34 (Class A, obviously). It has just 2 volume controls - the first a typical gain staging control and the 2nd essentially an FX Return/Master Volume control (yes, it has a buffered FX loop for adding... well, anything). It's pretty amazing, simple AND flexible.
  3. JIMMY JAZZMAN
    JIMMY JAZZMAN Tele-Holic
    Baltimore
    Guitars and amps are organic. Never the same twice. Look it up.
  4. strat a various
    I just looked it up. Turns out, though amps are partially carbon based, they are largely inorganic. Some of the do host small organisms, though.
    breadfreak and NTC like this.
  5. TelZilla
    TelZilla Friend of Leo's
    Cleveburg, USA
    My 5f1 might as well not have a knob. That things been dimed for 8 years.
    After all theres a knob (2,even!) on the guitar
  6. TelZilla
    Cleveburg, USA
    Try telling that to a blonde piggyback bassman and it will kick your a*s
  7. strat a various
    That works for blondes in general, mostly.
  8. HF1600ie
    HF1600ie Tele-Meister
    Atually, one of my best amps is a Vox AC30CCH (2007 model). It has the top boost and normal channels.
    Once I modified the amp internally to my specs (the old Vox specs) I find my self turning it ON, adjusting volume and playing. No really need to fiddle with anything else. Top boost channel with tone controls at noon. Adjust volume/gain to taste.
    The Normal channel is even more simple : A volume control and a "brilliance" or "more" brilliance" switch. Choose the switch position and that´s it. Play! Have fun ! I focus more on my playing and my guitar.
  9. Guitarzan56
    Guitarzan56 TDPRI Member
    S.E. Wisconsin
    OK I know this isn't what you were referring to but I couldn't resist showing you this.
    I've had an amp with no controls for years. The lap steel it came with had V & T and I suppose that was where they expected you to control it. But not even a power switch? That's taking simplicity to a crazy level. It has a surface mount fuse on the inside. When I recapped it, I added a vintage looking but safe (grounded) power cord and an inline switch I got from Vintage Wire and Supply. I just didn't want to be the first to drill any new holes in it after it survived maybe as many as 80 years as pictured.
    NTC and subgenius_one like this.
  10. DrBGood
    DrBGood Tele-Holic
    Sutton QC, CANADA
    Gotta name for your new amp company: ULONTRIPON Amps (ULtimate ONe TRIck PONy).
  11. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Silver Supporter
    Oregon Coast
    My curiosity is how do you get to the set-it-and-forget-it point without knobs?
    It seems pretty straightforward to get your signal up to line level for a power amp to process, but where is the assurance it will produce the sound you are looking for without manipulating the preamp?
    Not damning the OP's idea. I like it, actually. Complicated is fun...for awhile. But, simplicity is always a welcome return.
  12. zeppelinofled69
    zeppelinofled69 Tele-Meister
    Buffalo, NY
    I see your valve junior and raise you a marshall 18W clone in a valve junior...
  13. zeppelinofled69
    Buffalo, NY
    I would expect during the build and design process the OP would breadboard the amp and use pots to get it where he wants it and then measure the pots to get the resistor value needed.
    Tedious, but totally doable.
    Old Deaf Roadie likes this.
  14. OneOcean
    OneOcean TDPRI Member
    Mystic, CT
    The VHT Special 6 would be a good amp to start with since it already has a Fender style tone stack with fixed resistors & caps you could easily mod to taste. The Volume and Tone pots could also be easily replaced with fixed resistors if you wanted. You could leave the 3-way power switch as-is which would give you two output tube volumes and different tones, High (Pentode) and low (Triode), and the amp also has Hi and Lo inputs which could handle switching to guitars with different pickups. So that is 4 different volume/tonalities without needing to turn knobs. The amp also has a Boost footswitch, which adds an additional mid resistor to the tone stack, which offers another volume/tone level, so potentially eight different volume/tones without ant pots!
  15. Guitarteach
    A master volume allows adjustment for psychoacoustic balancing in different environments.
    My champ build has a variable B+ control... all the magic is in that control. There is a sweet spot.. BUT only for one environment. I need to adjust both gain and power to get same feel somewhere else that soaks the sound differently. So ultimately it would frustrate.
    get a simple multifx and a power amp. Then make it a patch.
    i could imagine a 5 way rotary, varitone like selector changing a resistor array for two controls altering the gain and power on my champ though for 5 presets. A good middle ground.
  16. oldunc
    oldunc Tele-Meister
    California
    I have a little Kustom tube amp that only has a volume control, which is fine by me. But I'm not much of a knob twiddler anyway, I like to concentrate on sounds I can make with my hands.
  17. gkterry
    gkterry Tele-Afflicted Silver Supporter
    the Telecaster Forest
    Mexitele Blues likes this.
  18. thechad
    thechad Tele-Holic
    Kamloops
    In theory you could do it, but it’s kind of like opening up your pantry and throwing out all of your herbs and spices except for salt and pepper.
  19. strat a various
    Some amps have Tabasco built in.
  20. jsiddall
    jsiddall TDPRI Member
    Ottawa, Canada
    I am building my own with exactly 0 knobs:
    Technically it has a power switch on the back, but normally it isn't used and the power is controlled by USB:
