Amp thermal fuses
Discussion in 'Amp Central Station' started by GuitarJonz, Aug 13, 2016.
  1. GuitarJonz
    GuitarJonz Poster Extraordinaire
    MA
    Have seen some recent posts about inexpensive amps that have thermal fuses, which are not easily replaceable, and often hidden under pcb boards, or other inaccessable places. Also seen posts where guys say their tech "took care of it by rewiring", which I assume may mean wiring around the fuse, ostensibly leaving it unfused. Why not just have a vintage style fuse holder, where the amp owner could just unscrew the cap and replace the fuse? Is it just cost, or are they trying to keep the tin foil pirates out of there?
  2. 6942
    6942 Poster Extraordinaire
    Santa Fe, NM
    The cost to buy a Vintage style fuse holder and the cost to install it.....should.....be minimal.
    I build a LOT of guitar and stereo (audio) amps.
    It's $3-$4 dollars for a NOS Buss fuse holder (if you shop around), and roughly a 20 minute job, to drill your chassis and install it.
    Steve
  3. jazzguitar
    jazzguitar Tele-Afflicted
    Germany
    I do not think there is a general answer. Some companies' products are made to break, others are made to work and last, and in the latter case I think it is sensible to assume that thermal fuse will rarely have to be replaced.
