justahuman
AMP: Used Mesa Boogie Solo 50 Single Rectifier (just got in mail from Guitar Center)
PREAMP TUBES: V1, V2, V3 - JJ ECC83S; V4, V5 - no name Chinese 12AX7A
POWER TUBES: JJ 6L6GC, Tube Depot-15
FUSE RECOMMENDED: 2.5A Slo-blo
FUSE INSTALLED: 3A 250V
ISSUE: Sounds like tremolo whenever master volume is high. Left power tube pulses blue light in sync with sound (video below shows this happen as soon as the master reaches a certain threshold). Occurs on both channels, even when individual channel volumes are at zero. Right power tube looks fine, but its socket appears to have some scorching (could have occurred before old owner replaced tubes and sold to GC).
ATTEMPTS TO FIX: Cleaned jacks, straightened preamp pins & reseated, cleaned power tube pins and reseated, patch cable in effects loop, double checked cab impedance w/ multimeter, tried diff. guitars and cables. I have a brand new pair of JJ 6L6GC tubes, but don't want to try them if the issue might take them out, too. Any ideas?
