Jewellworks
ive got my first amp repair job on the bench. it was first brought in because he was complaining bout a god awful Hum. he had fussed with it forever and finally gave up and brought it to me to look at. turns out, that was the easy part. the ground wire had popped off the filter caps from the biasing diode. put it back on, no more hum.
BUT
he wants me to look it over. theres been some hacking in here.
this amp is a Granger (?) KIT of a Marshall 50W Plexi. at first, i assumed it was the 1987 circuit. seems reasonable with the solid state rectifier, 4 input jacks, ect. im still holding that to be "mostly" the case. but the power section is wired very weird...
the schematic shows the Standby switch directly off both legs of the PT 2ndary, on a DPDT Switch. so basically, the heaters come on w the Mains, and the bias has its own tap off the PT, and it continues on to the diode and caps, ect... and feeds the grids of V4 and V5. nothing else is powered unless you close the Standby switch.
this one is wired very differently...
with the standby switch open, Mains ON, you get heaters, the bias, and both legs of the 2ndary continue on to the rectifier. once past the rectifier, it feeds the 1st filter cap (2, 50uf's together for a total of 100uf) then stops. the Standby switch is a SP and its fed 550VDC off the rectifier. once closed, it feeds an HT fuse, the choke, and the rest of the circuit...
1st of all... 550VDC on that switch? that doesnt sound right. if the DP switch was there, each would be getting really high AC voltage. so is it hurting anything to have THAT high DC running through that switch?
this amp also has test points for V4 and V5, off the cathode, which goes to ground through a 1ohm resistor. im not sure what that tells me.
BUT
