Amp just died. Found a cockroach inside... help?
Discussion in 'Amp Central Station' started by Jalpow, Mar 31, 2012.
  1. Jalpow
    Jalpow Tele-Meister
    Melbourne AUS
    Hi all,
    Just created this thread to see if I could get some advice on what to do now.
    I have a Blues jr iii and when turned on all i get is a cracking fire-sort-of sound out of it. This increases as I turn the volume up and engage the fat switch. It had been working perfectly fine just a few hours ago.
    All the tubes are glowing a nice amber/orange colour and I only replaced the power tubes a month and a half ago to JJ's.
    I opened up the back and wiggled the tubes when I saw a small cockroach scuttling around the inside which I then killed.
    Can someone give me advice on how the revive my beloved amp? Is it the pre-amp tubes that need replacing? I haven't replaced them in the year since I've had the amp. Is it possible that the cockroach inside had been feasting on the circuit-board?
    Thanks in advance. Greatly appreciated.
  2. Donald77
    Donald77 TDPRI Member
    belgium
    euh, that is Poowey! I would check the inside of your amp first and then get rid of those nasty bugs in the room.
  3. jmiles
    jmiles Friend of Leo's
    ohio
    The "roach" is what makes the tremolo work! You killed it!
  4. ASC67
    ASC67 Friend of Leo's
    Minneapolis, MN.
    Call an exterminator.
  5. ASC67
    Minneapolis, MN.
    There is usually more than one cockaroach.
  6. RubyRae
    RubyRae Friend of Leo's
    Cincinnati
    Man, this is really gross, I hate those things. Take it to a tech.
  7. BiggerJohn
    BiggerJohn Friend of Leo's
    California
    The roach probably ate through a component.
    Get a can of RAID.
  8. caferacer
    caferacer Tele-Afflicted
    phila pa
    SET IT ON FIRE!!!!!!!!!!
    (I hate bugs)
    sorry about your amp,
  9. Warm Gums
    Warm Gums Friend of Leo's
    not here
    It's possible that you zapped a companion and shorted across a trace, not likely but possible
    It's more likely that you are storing the amp in the humid/moist environment that theCR enjoys and that may be causing your problems..but you really want to clean that out..
    I just finished cleaning up a used amp that was pretty mucky, when I dropped the chassis a1/2dozen spider egg sacks were attached, wound not have been pretty in the studio.
  10. Tele Fan
    Tele Fan Friend of Leo's
    Louisville, Ky
    If it's a new amp and you don't have a history of roaches in the house, I'd take it back for an exchange. If not I'd take it to a tech.
  11. Flipped Mustang
    Flipped Mustang Tele-Holic
    Nor Cal
    Just blew coffee out my nose :)
    Seriously, you need to take the amp outside and open it up to see if it's infested. My brother purchased a used, very clean looking laptop which he brought into the house. There had to be 100 roaches hiding inside. They love electronics. When he sent it to Dell to fix it, they returned it with a large red "BIOHAZARD" sticker on the box and refused to work on it.
  12. Jalpow
    Jalpow Tele-Meister
    Melbourne AUS
    Its odd. My family is consists of a few clean freaks who are constantly cleaning, you wont even catch dust on the window sill.
    So you guys are sure the circuits messed and not just a pre-amp tube? Just to repeat, when I turn on all i get is a crackling noise although all tubes light up.
  13. brookdalebill
    Austin, Tx
    Entirely different that the roach I found in that Blackface Super
    I bought in high school.
    Amp sounded great, just smelled funny.
  14. DoodlySquat
    DoodlySquat Tele-Holic
    Uranus
    Yes you'll have to buy a replacement roach, I'm sure you can get a good vintage one if you look hard enough on eBay and CL.
  15. toadman
    toadman Tele-Afflicted
    andoverandoverandover,ct
    old ampegs are a bit different from the Blues Junior. i opened up my 65 rocket to look at the trem and this is what i found:
  16. caferacer
    phila pa
    you should see the size of the "POWERAT's in my S.V.T.
  17. Dave_O
    Dave_O Friend of Leo's
    offline and IRL
    Don't kill it. It's actually a mojo bug.
  18. Jim Dep
    Jim Dep Friend of Leo's
    New York
    Stick a Roach Motel inside the cab and seal it back up.....
    Maybe they're having an orgy in you spring reverb?
    Or, if that dont work... try DECON spray....cause "Ah dont want you livin' with no roaches.."
  19. Unadan
    Unadan Tele-Holic
    Portland, Oregon Metro
    That roach, after years of living inside your amp, may have been imbued with great knowledge and wisdom of the inner workings and circuitry of your amp - becoming almost an in-house engineer and technician constantly troubleshooting and fixing internal problems as they arose. He will be missed.
  20. Pointmonger
    Pointmonger Tele-Holic
    Austin, Texas
    Call Fender. Maybe it's some sort of contest. If yours is the amp with the roach, you win a Custom Shop Tele. :lol:
