Amp corners
MrCoolGuy
Fort Worth, TX
Hello everyone.
I'm making a speaker cabinet and amp head for someone... so far they are looking pretty cool (I will post pics when done... want to surprise the owner.).
The hardware I'm using (bolts and side handles) are a pewter color metal. I would like to find some corner protectors that match, but all I can find is chrome (stainless), black and gold. Just the basic ones you always see. Does anyone know where to find any alternative? Thank you.
MrCoolGuy
Fort Worth, TX
Have you checked Mojotone?
Yes, sir. Thanks, but they just have the same ones everyone else does. I found some on a furniture website that look how I want, but they are too small. Then I found a lot of decorative corners that are very cool with engravings and such. But they are for pointed corners, not rounded over edges/ corners.
5595bassman
Montreal Canada
Some black one have a flat finish that can be painted.
Powdog
Cool, CA
You can buy leather corners from Mesa Boogie, come in a few colors. These are the brown ones.
Tim S
Gold Supporter
Upstate NY
If you cover the amp during transport, it limits the opportunity for the leather to be scraped. Unlike metal corners, the leather is flexible enough not to dent, if struck. I’d tell you to look at used Mesa to get an idea of how they wear, but non-touring Mesa owners (including myself here) tend to baby their amps.
MrCoolGuy
Fort Worth, TX
Yay, you're right! I'm sure they/ you do. Lol
chas.wahl
NYC
Presuming that the painted corners you can buy are steel: you could buy some, strip off the paint, and then use a phosphoric acid treatment on them, which will turn them a matte dark gray. This is a conversion process widely used to remove rust and scale from steel surfaces. Here's a video giving you an idea of the process and the resulting color on steel:
Depending on the use/abuse the corners get, they might get scarred up a bit exposing the brighter steel underneath, and they might also rust if exposed to water, salt, etc. Phosphoric acid is generally used as prep for something that's going to be painted, as the video suggests, but it does leave an inhibitive layer on the steel surface that's worth something.
MrCoolGuy
Fort Worth, TX
That's cool... I actually thought about oxidizing some metal corners a little too make them look old. I was going to use a few drops of the ferric chloride I use to etch circuit boards, but I'm sure phosphoric acid works equally or better.
