Leather looks awesome combined with wood, for sure its a perfect choice!so will a leather handle go on top of the head?
Since youre still working on it... You know gear changes, you change.. Make a panel to have a fully closed back option as well!Also, the cab is semi open at the back
The most important thing to take into consideration when choosing a handle for the top of your cabinet is clearance between the handle and the amp on top of it. Famously, you can't stack a Fender amp with glides on top of another Fender amp with a strap handle without it teetering and tottering, because the handle is thicker than the glides. So just make sure that you have feet on your head that are high enough to clear the handle.They say the most stupid questions are the ones that don’t get askedso will a leather handle go on top of the head? Remembering it’s a lunch box type now, as I’m struggling choosing handles, and there’s a limited selection with brass fittings.
Also, the cab is semi open at the back, was there an optimal size for the opening or is it random as it appears?(when I went to the store for the greenback I had a nosy at the back of their amps).
I don’t know how you get anything done with those toolsView attachment 975211
Something to start with and I can see where I'm going with it now, not glued up yet as I want to get the vent holes in first.
Thank you!Great workmanship Kev! Just something you may have overlooked could be airflow vents in the actual floor of the amp cabinet. They don't have to very large but with the circuit containing valves and capacitors/resistors etc. they can produce fairly high temperatures so a couple of screened vents in the base of the amp cab will allow the component part of the circuit to vent off some heat during extended on time!
You have done a great job building it by the way!
Reminds me of an amp cabinet I built for an ex-boss of mine which was made with three 10inch speakers driven by a high powered valve amp. Sadly his home was severely flooded about a year after he got it and was totally ruined!
Good work mate!
DC
