Am I nuts, or do Esquires have a more resonant tone?
Discussion in 'Other T-Types and Partscasters' started by RoscoeElegante, Apr 25, 2017.
  1. RoscoeElegante
    RoscoeElegante Friend of Leo's
    TooFarFromCanada
    I've been playing several for a while now, A-B'ing them with one another, Teles, S-types, non-Fender types, etc. Maybe it's just a narrow sample, but the Esquires seem considerably more acoustically resonant than T-, S-, and other types. And some of this seems to transfer to/show up when I play them electrically, too.
    Is it the unbroken pickguard vibration platform from the bridge plate to the neck? Fewer magnets? Saturn is napping? Or am I just *aurally leaning into the guitar to compensate for its lack of a neck pickup?
    Interesting, too, how the one-pickup design just invites more expressive and exploratory play, as it seems to say, "You gotta pitch in a bit more here, bub." Which suggests that * above explains my "more resonant" impression.
    When I get fired from my job because I'm sitting here daydreaming about guitars I will buy lottery tickets to fund my Psycho-Acoustics PhD.
    And then a lot of very generic cat food for the mid-quality box beneath the bridge.
    Ear-hugs from Psycho-land.
  2. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    It's probably due to less magnetic pull. An A5 rod jammed up into the string can dampen vibrations a lot. I like lower gauss magnets for this reason.
    SceroGuitars and theflow like this.
  3. Bellacaster
    Bellacaster Tele-Afflicted
    Ypsilanti, MI
    I think there is to be something about not having the magnetic pull from the neck pickup. Might be something psychological about knowing there isn't one there also.
  4. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    I guess you are noticing the lack of slight dampened effect with no [as said] neck PU. Question is, if plugged in and with gain is it relevant?
  5. brookdalebill
    Austin, Tx
    How are such things quantifiable?
    I have a pro player friend who swears that Esquires and LP Juniors have have a unique and superior tone to their dual pickup cousins.
    I don't hear or get it, but my friend is a great player, singer, and guitar tech.
    I have only owned one Junior, a 56.
    It did indeed sound great, but I NEED a neck pickup.
    Ricky D. likes this.
  6. Jupiter
    Osaka, Japan
    I'm a bit skeptical about the absence of a neck pickup having an appreciable effect on tone, but I sure do like the way my laCab clone sounds, and it only has one pickup...
  7. cboutilier
    cboutilier Tele-Afflicted
    Halifax, NS, Canada
    The electric guitar skeptics swear that the strings and pickups are the only part of an electric that effect the tone. The neck pickups magnet HAS to act on the strings, but to what effect I cant say.
    By that definition, an Esquire must have a different tone. Whether or not the difference is enough to be picked up by the human ear, I can not say.
  8. ndcaster
    ndcaster Poster Extraordinaire
    Indiana
    hmm, this stuff is measurable -- for example, keep everything else equal, and video high-res string vibration with two pickups, and then with one bridge pickup -- if there's no difference, there's no difference
    you could also measure body wood vibration somehow, again with no neck rout vs maybe a swimming pool rout, just to exaggerate differences so you can see any differences more clearly
    maybe look at Esquire bridge pickups for better answers: if they're A5, I think flux density will differ from the looser flux densities of A2 or A3, and differences in Gauss may affect things, too
    just trying to mess things up here -- my hunch would be that what we hear as "resonance" is complicated and affected by more than wood
  9. Slim
    Slim Tele-Holic
    Fayetteville, AR
    Rocker dude Phil X is a big believer that the neck pickup affects string pull and has guitars designed without them because of it. It makes sense in theory, but Les Paul's are pretty notable for sustain.
  10. h4ck.b0x7
    h4ck.b0x7 Tele-Holic
    United States
    The humbuckers in a Les Paul don't exert as much pull on the strings as a single-coil Fender style pickup. They don't call it Les Paulitis.
  11. crossroader
    crossroader Tele-Afflicted
    Endicott, NY
    Well, the magnetic pull from a neck pickup would certainly have some impact on string vibration. The question then becomes, how much of an impact?
    And can that impact be heard?
    For me, the answer to the "Can it be heard?" question is no.
    When I first bought my (MIM Reissue) Esquire, I played it for a while in it's Esquire configuration.
    Then I installed a Barden neck pickup.
    I didn't notice any difference in (a) the acoustic tone or (b) the amplified tone of the bridge pickup.
    Of course, my conclusion is based on a very small sample (1) and a complete lack of measurement tools.
  12. JD0x0
    New York
    I can say. Ever hear of the term 'Stratitis'? This is the made up word we have given to excessive magnetic damping on strings, which can be fairly common on strats. It can be severe enough to effect intonation and pull strings out of pitch. That is a very profound damping caused by magnetism from alnico rods in the pickup(s)
    There's also the fact that as we move away from the saddles, towards the middle of the scale, (where the neck pickup is positioned) the magnets will have more and more leverage over the strings. So a single neck pickup will exhibit more string pull than a single bridge pickup, adjusted to the same height, with the same magnets. If we take this into effect, adding a second pickup, to the neck position adds considerably more than 2x the magnetic pull of the original single bridge pickup. That could be considered pretty significant, if you ask me.
    The term 'stratitis' obviously came from the fact strats have 3 pickups, thus more magnetic pull than a tele or esquire. The shielded tele neck pickup also tends to cause slightly more distance from the string to magnet compared to the open rods on a strat style pickup. This is why you rarely hear about magnetic pull issues on teles or esquires.
    cdwillis and hemingway like this.
  13. barnbustud
    barnbustud Tele-Holic
    asia
    i had the same experience recently and I'm glad I did.
    Wonder if I could replace that bridge pup with a neck in the bridge position.
    Is there a way to make the dark position less dark.
  14. perttime
    perttime Tele-Afflicted
    Finland
    I'm told strats can get absolutely weird if you raise the neck pickup enough.
  15. JD0x0
    New York
    Change the cap it uses. I often find 'dark' caps and the like to have too high values which sounds like mud. You'd probably want something significantly lower than the original value.
  16. hemingway
    London, UK
    I used to have the pickups on my strat really high because they distorted so nicely. But the dampening and fret buzz were too much of a problem.
    I often wonder why strats are considered such a great design when they have so many problems. I suppose the answer is that, if you can live with all the issues, they just sound good sometimes.
  17. tintag27
    tintag27 Tele-Afflicted Silver Supporter
    Old England
    'Mountain' guitarist Leslie West always maintains that the single pickup is the better tonal option...
    SnidelyWhiplash and RoyBGood like this.
  18. RoyBGood
    RoyBGood Doctor of Teleocity
    Northamptonshire, UK
    'Am I nuts, or do Esquires have a more resonant tone?'
    No you're not, and they do. ;)
    rebelwoclue likes this.
  19. MonkeyJefferson
    MonkeyJefferson Tele-Holic
    Nonurbana
    I have one, with a Duncan Antiquity II, and all I can say it makes EVERY sound I ever wanted out of a tele bridge....
  20. shinigami747
    shinigami747 Tele-Holic
    NJ
    In my experience messing around with my partscaster:
    Yes, there is.
    More lively both clean and slightly dirty.
    Heavy gain - no difference.
