Am I going to hurt my amp?
Discussion in 'Amp Central Station' started by howlback, Apr 19, 2016.
  1. howlback
    howlback Tele-Meister
    Los Angeles
    I have a '68 drip-edge princeton amp and I'm worried about pushing it beyond it's limits. Gigs are starting to happen in bigger clubs. Last one I had my monitors cranked because I couldn't hear the Princeton too well. I had it on about 8 or 9. I'm worried about running the amp that high all the time and I'm also worried about the speaker because it's an original.
  2. keithb7
    keithb7 Friend of Leo's
    Western Canada
    It will be fine. Crank it up. It was made to. The power tubes may wear out sooner than if you played it at lower volume.
    Carry a spare matched set in case needed. Is it an original '68 or a '68 CPR? 68 CPR The speaker was made to handle the power. If you like dirt then give 'er.
    If it is an original speaker, it's probably already done in.
  3. howlback
    Los Angeles
    It's vintage. I might take it to get checked out, see what's all been done to it. Other than a three-prong cord, I'm not certain what's all going in there. Sure sounds good though.
  4. Ira7
    Ira7 Doctor of Teleocity
    Coral Springs, FL
    What else matters?
    Just drive the S out of it, and have whatever with you as a backup for gigs.
  5. Silverface
    Lawndale CA
    If it's never been serviced - for if you don't know FOR SURE - you are taking a big chance. It should be looked at by a qualified tech asap before you end up with VERY expensive repairs. And I would remove the stock speaker...which loses quite a bit of power handling over time - save it, and install a good sub for gig use.
    Wally and BobbyZ like this.
  6. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Have it serviced and checked if you never have, then play the snot out of it. Tube amps are meant to be pushed.
  7. Luthier Vandros
    Luthier Vandros Tele-Holic
    Down by ya mom an them's
    Service it ASAP - a blown tube, shorted cap, etc...can all smoke a tranny.
    Wally likes this.
  8. clintj
    clintj Friend of Leo's
    Idaho
    Just to offer up another idea, have a copy of your vintage one made and take that one gigging. Then you don't have to worry about damage, loss/theft, blown speakers, etc.
    +1 on the recommendations to have it thoroughly inspected and given a clean bill of health. A blown filter, bias cap, or smoked power tube grid resistor can wreak a lot of havoc in a tube amp. Once that's done, no worries.
    Wally likes this.
  9. 1300 E Valencia
    Fullerton CA
    If the speaker is original, I'd switch it for something about 25-30 watts, new and more efficient, which should make it louder to boot. Keep the original speaker safe if you ever sell the amp. Same with the tubes, if they are original as well. Fender skimped on speaker power handling on the "student" models.
    Chicago Matt likes this.
  10. howlback
    Los Angeles
    Any recommendations for a tech in LA?
    snottyboy and BobbyZ like this.
  11. Chicago Matt
    Chicago Matt Friend of Leo's
    Woodstock
    +1, great advice there ^^^
  12. Silverface
    Lawndale CA
    Depending on where you are, Jim Foote at Music Works in Lawndale (especially for Fenders and Marshalls) or Don Butler out in the San Fernando Valley (a Vox specialist but great on everything).
    Both are superb. And both are buried in work, so plan on at least a 3-4 week lead time unless you get VERY lucky. The techs who can turn them around in a couple days on a regular basis are ones to avoid.
    But as this is actually a simple full-service job and a speaker replacement (save the original in case you ever sell the amp) it's a pretty quick job, and sometimes Jim or Don will knock these out in a week or so. IF you get lucky.
    Neither is always Mr. Personality, and have little time for chit-chat - just tell them you don't think the amp has ever been serviced, and buy a speaker and bring it with you (I suggest something from Weber or Warehouse Guitar Speakers), tell them precisely what type of music you play and that you crank the amp - otherwise they do a "middle of the road voicing and bias setup which may not fit well with what you do. Provide as much detail in a short time as possible.
  13. howlback
    Los Angeles
    Well, here she is...
  14. tery
    tery Poster Extraordinaire
    Tennessee
    A 68 Princeton is my dream amp - Play it loud !
  15. DaveKS
    DaveKS Friend of Leo's
    KS
    Yep get you a new speaker. Jupiter or Alltone 1040 will probably gain you about 3-4db, that'll be like 20% increase in volume. Then get her serviced and tuned up.
  16. Johnny Cache
    Johnny Cache Former Member
    Oregon
    The amp can handle it if it's in good condition, make sure you have good tubes and it probably replace the filter cap can. I think a higher wattage speaker would be a good idea if you're pushing the amp hard. I stuck a Copperhead in mine and I think that was a big improvement. I don't push my amp very hard since I mostly play Jazz at lower volumes. You might think about getting a Deluxe Reverb if you're always pushing the amp hard.
