Always out of tune?!!
Discussion in 'Telecaster Discussion Forum' started by Chedbaze, May 3, 2017.
  1. Chedbaze
    Chedbaze TDPRI Member
    New York
    So. My MIJ BLUE FLOWER TELE won't stay in tune. It's mostly the E A D and G strings. B and A are fine. Crazy thing is that it detunes higher not lower. Is it the vintage style tuners?, the nut seems fine with plenty of space for each string. Any advice?
  2. brookdalebill
    Austin, Tx
    Cold room?
  3. Papa Joe
    Papa Joe Friend of Leo's
    Swanton Ohio
    The strings are hanging up somewhere..
  4. MilwMark
    near Arnold's
    Do you mean open strings are in tune, but fretted notes up the neck are not? Then you need to intonate the guitar?
    Fenders are pretty simple. Tuning issues are rarely caused by tuners themselves.
    Normally, it is the nut, but it can be other things.
    Chedbaze likes this.
  5. RoyBGood
    RoyBGood Doctor of Teleocity
    Northamptonshire, UK
    Un-stretched strings? Strings not installed properly? Non-lubricated nut? All relevant screws (neck plate, tuners, bridge plate) need tightening?
  6. blille
    blille Tele-Afflicted
    Bay Area - California, USA
    The nut.
    aerhed and Chedbaze like this.
  7. backporchmusic
    backporchmusic Friend of Leo's
    Nut.
  8. Tom in Georgia
    Tom in Georgia TDPRI Member
    Georgia
    I have a similar problem with a MIM Strat when we go from having heat on in the Winter time to AC in the Spring.
    Tommie
  9. Obsessed
    Montana
    Warm up the strings by doing some strumming and playing before you tune.
    Manual Slim, Chedbaze and PCollen like this.
  10. brenn
    brenn Tele-Afflicted
    Kentucky
    All of my guitars are always get a little higher when they have been sitting around cold for a day or two. Since that's about a hundred guitars and 25 years, and includes guitars with locking tuners, roller nuts, tremsetters, etc., I figure it's normal.
    Yep, that's what I generally do.
  11. PCollen
    PCollen Friend of Leo's Silver Supporter
    Man of the World
    What guage strings are you using ? As others have suggested, it may be the nut...lube it up.
  12. Chedbaze
    New York
    I'm gonna go with this. Thanks! I'll also run a little pencil in the nut for good measure, but a hundred guitars?! I'd be a fool not to go with you on this.
  13. blille
    If B and A are always fine and not the others, my money is in the nut. It may be more than pencil, you may need to file make sure they fit well.
    Weather affects tuning, no doubt. But not like the weather affects just 2 out of 3 of the high and low strings. Just saying.
    John Owen likes this.
  14. MilwMark
    near Arnold's
    Wait, do you mean it pitches up when you leave it for a day or two (or longer)? That part is normal. String tension and all that.
  15. Cesspit
    Cesspit Tele-Holic
    Oxfordshire England
    Check what everyone else has said but also check intonation. If ever I have tuning issues I go there first, it's a common culprit.
  16. brenn
    Kentucky
    I would be more surprised if it has been less than 100 guitars than if it has been more. I started this thread about a list of my guitars that I found, where I started writing down an inventory, back around 2000, but this is just what I had in the house that day, if it's even all of them. They changed on a weekly and sometimes daily basis.
    http://www.tdpri.com/threads/the-good-old-days-when-i-had-lots-of-guitars.646503/
    In those days, having 30 guitars in the house at a time was no big deal and I probably spent more free time buying, selling and trading than playing.
  17. Obsessed
    Montana
    I have never had a nut issue nor a tuner issue. I have cheap tuners, expensive tuners, open tuners, synthetic nuts, bone nuts, acoustic and electric guitars. Live in a house using wood heat, so daily temperatures can vary 15 degrees. I have turned on so many guitars players to strumming a few minutes to warm up the strings before tuning and that solves their tuning issues. Not to say, if you change string gauges, don't stretch new strings, wind the strings incorrectly on the tuner shafts or intonation is incorrect can affect tuning, but by in large, warming up the strings seems to be the problem most of the time.
    MadRocker likes this.
  18. RoyBGood
    Way too much neck relief could do that.
  19. Tim S
    Tim S Tele-Holic
    Upstate NY
    Don't you mean too little relief? It sounds like the truss rod's tension is overwhelming the strings, stretching them sharp?
  20. RoyBGood
    No, if there's too much relief, as you go up the neck, there's an increased gap between the strings and frets, so by the time you've made contact, you've done a small 'vertical string bend'.
