"Always On" pedal
Discussion in 'The Stomp Box' started by scout2112, Aug 29, 2018.
  1. a_pidgeon
    a_pidgeon Tele-Meister
    Scottsdale, AZ
    Compressor. Mine has two compression stages and a dry through. I use it for relatively subtle parallel compression and it's on as long as the amp is.
  2. GuitarJonz
    GuitarJonz Poster Extraordinaire
    MA
    Interested in the Dyna Comp with tele, can you describe your settings, anjd what it does for your sound? Was thinking of grabbing one for slide, but not sure how to use it non-slide.
  3. Rextrade
    Rextrade TDPRI Member
    Brooklyn, NY
    Used to be the Fulltone Fatboost 2. Really sounded great and slightly fattened up my tele pickups. Since I swapped in a p-90 neck and hotter bridge I don’t always have it on. I just got it this week, but the Walrus Messner may be my new always on pedal. I haven’t owned it long enough to know yet though.
  4. drlucky
    drlucky Tele-Holic
    Fresno, Ca
    I set the volume at 3 o'clock and the sensitivity on 9 o'clock. Adds a bit of clean sustain and shimmer on the Tele.
    awasson likes this.
  5. kafka
    kafka Tele-Afflicted
    Potomac, MD
    Does the Belle Epoch have the preamp on the direct signal, or just the repeats? I was under the impression it was just the repeats.
  6. 3-Chord-Genius
    Winchester, VA
    TC Electronics Dark Matter Distortion, and BOSS DD-5. Both are always on, and I tap the delay tempo to each song.
  7. ebb soul
    Smyrna georgia
    TC Arena 'verb.
    BuckSatan likes this.
  8. PigBoy
    PigBoy Tele-Meister
    San Francisco, CA
    EP Booster with the boost off just to sweeten things a bit.
  9. Iago
    Iago Friend of Leo's
    Brazil
    Compressor (Bearhug Compressor by Jon Patton) with both Tele and Strat for the clean sound only and only when playing live. It provides me that extra bit of consistency. I use a very middle of the way setting.
  10. MilwMark
    near Arnold's
    No. I used to. Then I found amps I like. I used to scoff at that statement.
  11. dreamingtele
    dreamingtele Friend of Leo's
    Melbourne, Australia
    My always on pedal is my first stage drive, tumnus deluxe and ep booster..
  12. tweedtone
    tweedtone Tele-Afflicted Silver Supporter
    Tampa Bay, FL
    I have my Belle Epoch in trails mode so that the EP-style preamp is also on; I have it set for a slight boost.
  13. Obsessed
    Obsessed Telefied Silver Supporter
    Montana
    Three always on for me nowadays:
    VFE White Horse compressor
    VFE Pinball Tilt EQ
    Subdecay SST reverb on "room"
    RetroTeleRod likes this.
  14. cigarman513
    cigarman513 Tele-Meister
    Boston
    Mystery Brain
  15. CAAD8N8
    CAAD8N8 Tele-Holic
    Ohio
    TC Hypergravity compressor to smooth things out and balance the frequencies a bit
  16. wrathfuldeity
    wrathfuldeity Tele-Afflicted
    Turdcaster, WA
    ehx lpb 2ube for a tube buffered pedal board
  17. jman72
    jman72 Tele-Afflicted
    Central Florida
    Hall of Fame reverb (through my 5e3). Unless I'm playing a really crunchy song (like Green Day), then I'll turn it off.
  18. 4pickupguy
    4pickupguy Doctor of Teleocity Silver Supporter
    Fort Worth, Texas
    No always on pedals (not counting my preamp pedal or no sound would come out) but my BD-2 is on about 60% of the time[emoji53]. Should I be concerned?[emoji45]
  19. El Tele Lobo
    El Tele Lobo Poster Extraordinaire Silver Supporter
    For me a Tone City Comp Engine...but i don't keep it set very compressed. Compression is set at like 3 o'clock. Volume and attack at like 1 or 2.
    I also usually leave my TC Electronic Spark Booster on in some capacity. It has a clean boost setting that just fattens up my tone nicely and brings out all the frequencies. Sometimes I switch to the fat boost setting for light overdrive or to stack it with my Mosky Golden Horse.
    I also usually use some kind of delay, but it depends what i'm playing. Mostly variations of slapjack, but sometimes just a little for dimension, other times (rockabilly) a little more and when I'm playing worship stuff and some ambient stuff, I sometimes use cascading delays or stacked delays...and occasionally experiment with longer times or reverse settings.
  20. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Same here, but it's an OD-3 for me.
    JustABluesGuy, RetroTeleRod and brogh like this.
