Always on buffer/Boost...
Discussion in 'The Stomp Box' started by Muzik4Machines, Dec 1, 2015.
  1. Muzik4Machines
    Muzik4Machines TDPRI Member
    quebec
    i have a klone and an EP boost, and i wonder which should go in front of the pedalboard and which at the very end, i plan to have one of them on at all times for the "color"
    the pedals in between are
    before the first buffer: volume and fuzz face
    *one of the buffer/boost
    clean loop: boss XT-2 (no gain, blackface-ish tone)
    dirt loop: "parallel fuzz", rat, fz2, pw2, tube screamer, ds-1
    post loops: DD3, DD6
    i also thought about putting the klone in the clean loop but then i loose it in the dirt
    the whole chain between the fuzzface out and the last boost/buff is in a true bypass loop so i can go guitar, FF, boost, amp for pure tone
  2. waparker4
    Philadelphia, PA
    100% personal taste. It sounds like you have two options, try them both. There is no right answer.
  3. Muzik4Machines
    quebec
    i know:)
    i spend most of my weekends shuffling pedals around while recording to have different sounds for the tracks
    i just wanted advice and tricks from the community
    i hope boss makes an ES16 PRO so i can plus all my stuff in and just reroute them via the interface :)
  4. hongaku
    hongaku Tele-Afflicted
    Oakton, VA, USA
    I run my EP Booster after fuzz face. I have it (the EP) set to unity volume when the knob is all the way down; it seems to help the fuzz face sit/cut better in a mix (especially germanium fuzz face). At the end of my chain, I have an RC Booster (with a spark mini boost also at the end to act as a pure volume boost when needed).
    I personally think you may enjoy similar results with the EP after fuzz face; the klone would be better suited to booster duty at the end of the chain, IMO. But as pointed out above, try it both ways.
  5. GearHund
    GearHund Tele-Holic Gold Supporter
    East, Tx
    Not directly on point, but when you use a booster pedal, do you turn your amp down to compensate for the increase in volume? I'm not sure how a booster should work. If it boosts the signal at a certain amp volume, meaning increased volume I think, wouldn't you then have to turn the amp down to get it back to the previous volume?
  6. Muzik4Machines
    quebec
    i have a non master volume amp, i drive it around 80% (just a nice crunch) then i hit the boost at the max to get sweet overdrive
  7. xtrajerry
    xtrajerry Doctor of Teleocity
    Lehigh Valley, PA
    With longer cable runs or many pedals in line I like to keep boost set to unity and use it to prevent signal loss. Sometimes I'll use another in front of drive pedals to boost gain or after to boost volume.
  8. AxemanVR
    AxemanVR Tele-Afflicted Ad Free Member
    Minnesota USA
    Lately, for my cleaner tones, I too have been running my EP-Booster this way; to prevent it from overdriving the input while still letting it do its magic.
    For this setup I keep things very simple:
    Clean guitar>Compressor>Booster>Amp
    ...or, more specifically...
    2003 Fender '52 AVRI Telecaster > DOD FX-84 Milkbox compressor > Xotic EP-Booster > Mesa Boogie TA-15 TransAtlantic
    But for grittier stuff I'll crank the EP until I get enough gain to melt your freak'n face!
    I don't mean that literally of course, after all I'm not a monster...:twisted:
