Aluminum Chassis can it be grounded like a steel chassis?
Discussion in 'Shock Brother's DIY Amps' started by ouaouaron, Oct 9, 2019.
  1. ouaouaron
    ouaouaron TDPRI Member
    Saint Louis
    I am considering getting an aluminum chassis but I am wondering if you can ground to it with a solder lug and screw or bolt? is there anything special needed to do a chassis ground?
  2. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    LudwigvonBirk and telemnemonics like this.
  3. schmee
    Should be no problem. If it's coated, oxidized from age or anodized you may want to abrade the surface at the lug for good contact.
    wabashslim and Teleguy61 like this.
  4. telemnemonics
    I prefer aluminum and some have claimed that the same circuit sounds different in aluminum because of a claimed faster path to ground caused by aluminum being a better conductor than steel. Can't confirm any sound difference.
    Early Marshalls all had aluminum chassis, but one concern is the weaker material may sag from the weight of the transformers.
    I had to add a brace to one of my old Marshalls where the lay down PT had bent the chassis.
    Carr uses aluminum chassis, you can buy almost any hobby chassis in both aluminum and steel.
    wabashslim likes this.
  5. ouaouaron
    Saint Louis
    thanks, just what I wanted to hear
  6. printer2
    It is a good idea to use a stainless steel toothed washer under the nut. You get in trouble mixing metal types as corrosion can be an issue. SS and tinned parts help.
    King Fan likes this.
  7. ouaouaron
    Saint Louis
    thanks, that's a good idea
  8. wabashslim
    Sonorous Desert
    WOW! Now comes the NEW SUPER-HYPER-SPEED LIGHTNING ALUMO-CHASSIE BOXXEZ...for electron travel so fast they'll just be a blur! :eek::eek:
    From the people who brought you Monster Cables!
  9. telemnemonics
    If you really want the best you need a solid copper chassis.
    Tone of the gods though requires a sterling silver chassis.
    Old Deaf Roadie likes this.
  10. LightningPhil
    LightningPhil Tele-Meister
    Nottingham, UK
    Silver is an even better conductor.
  11. tubelectron
    tubelectron Tele-Afflicted
    France
    Indeed - I do this on all my DIY amps, all of them using aluminium chassis. No issue, never. ;)
    No. Use platinum. Very affordable compared to aluminium. :D
    -tbln
  12. Old Deaf Roadie
    Old Deaf Roadie Tele-Afflicted Silver Supporter
    Oregon
    I prefer titanium to ensure it is roadworthy.
    telemnemonics likes this.
  13. wabashslim
    Sonorous Desert
    According to the chart I linked above, silver is the best, mercury is the worst. I can attest to that - very messy, hard to drill, and it just makes me so EFFING MAD!
    Steve 78 and Axis29 like this.
  14. printer2
    Mercury is underrated. Used to be in thermostats and float switches and the stuff just kept on working. Then do-gooders that want to keep us healthy got in the act. Now just find a mercury chassis at a good price.
  15. LightningPhil
    Nottingham, UK
    Made a LP bridge from a bit of titanium. Wow do the sparks glow brightly and the big ones nearly set my shed on fire.
    From this I conclude titanium is the best DIY material for all purposes. Good luck with the chassis!
  16. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Mozart was a way better conductor than Phil Silvers
    :lol:
