Alternative Tone Woods? - East Coast
Discussion in 'Tele Home Depot' started by danadig, Nov 6, 2019.
  1. danadig
    danadig TDPRI Member
    Baltimore
    Hey all,
    I'm getting around to making my first build, and rather than waste money on a "body blank" online, I want to find a slab of wood locally to use for the body.
    I live in the Mid-Atlantic region on the east coast of the US. Wondering if anyone has experience with building with any local woods from the area and could recommend something?
    Some common woods I'm seeing are:
    • chestnut
    • walnut
    • red oak
    • red elm
    • spruce
    • aromatic cedar
    • cherry
    • poplar
    • pine
    Help please! :)
    crazydave911 likes this.
  2. guitarbuilder
    Of those on your list, I've used poplar, pine, and walnut for bodies. I'm in NY state. You'll find many of the ones in your list will produce a heavy body. Wood density and weight go hand in hand. The average weight that most like in a tele is about 4 lbs. You can do a thinline to lighten them up if you are dead set on one species.
    Poplar is botanically related to Alder. It is close pored and finishes nicely. It is economically priced. The drawback is the yellowy green tint, so you generally see an opaque paint on them. You can also probably find basswood which is fairly lightweight and stable. It has a non descript grain to it unless you put some clear oil on it.
    Many on your list are open pored timbers and would require grain filling if you wanted a smooth mirror like finish.
    Walnut is very pretty when oiled or cleared. It can be pretty heavy though.
    I'd probably suggest the poplar, pine, or basswood. Hundreds of thousands of Jackson style bodies were made with basswood and poplar. They are also some of the most inexpensive of the domestic hardwoods on the east coast. Other than prototypes that Leo made out of pine, it really came into favor about 15 years ago around here.
  3. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Chestnut is a great wood for a guitar body. It's easy to work, looks good, smells good, and the weight isn't bad.
    That Cal Webway and crazydave911 like this.
  4. Ronkirn
    Jacksonville, FL
  5. Jmwright777
    Jmwright777 TDPRI Member
    Idaho
    My vote is for poplar and pine. Both very easy to work with and the price point is forgiving. Are you looking at local suppliers (i.e. big box stores) or lumber yards? Even some construction grade douglas fir can make excellent bodies as long as you and work down the rounded edges to get a square and even seam. My first build was a poplar back (2 piece) and a quarter sawn white oak top (2 piece) both very different woods in level of workability. Do you happen to have a woodcraft or rockler located around you anywhere?
  6. dougstrum
    dougstrum Tele-Afflicted
    blu ridge mtn cabin
    Poplar is great; easy to work, not too heavy, and takes paint well. It'd be a good choice for your first build.
    Cherry is a very pretty wood for natural finish, it's stable and works easily as well. It is more expensive~
    I built my first guitar using cherry, 30 yrs later I still play it a lot:):)
    ale.istotle, BB and crazydave911 like this.
  7. Jim_in_PA
    Jim_in_PA Tele-Afflicted Silver Supporter
    SE PA near New Hope PA
    For my general non-guitar work, I use a lot of poplar, cherry, black walnut and QS White Oak. While I've used pine for test bodies, I'm not happy with the weight and have sourced some basswood from Hearne Hardwoods in Oxford PA (reasonable drive for you) to use for that task. For special look, I'll do chambered and a cap of whatever fancy is hanging around. Cherry is one of my all-time favorites and honestly, if I wanted an all cherry body, I'd still do it chambered because....weight.
  8. Nickfl
    Nickfl Tele-Afflicted
    +1 for poplar. You can even do a nice transparent finish if you dye it.
    dougstrum likes this.
  9. I_build_my_own
    New York
    Poplar all the way -easy to work with - easy and cheap to get on the east coast. example of transparent finish with clear coat. 7CE908A3-9004-46C8-9A6B-578616BE3E90.jpeg
  10. roffe
    roffe Tele-Meister
    Stavanger, Norway
    I've used pine, spruce and larch for guitar bodies. They're easy to work with, but prone to tearout when working. They also quite soft, they dent easily and need to be block sanded to keep from digging into the soft parts. My favourite of those 3 is larch heartwood, it seems like the fibres are shorter (less tearout) and a little bit harder. All of them smell great, especially old wood :)
  11. DrASATele
    North of Boston
    chestnut - I've used it, as Roger said, a great wood. The older the better. The reclaimed stuff is a favorite.
    walnut - I've used it, black, white, Claro, Bagstone ect all good (makes a great neck wood)
    red oak - Haven't used it, weight being my main concern, it can be used though
    red elm - haven't used it,it's on the list of things to try
    spruce - I've used it, it's a favorite, great in any condition (see Pine)
    aromatic cedar - On the list to try
    cherry - I love me some cherry and have used it for everything including a fret board (FB not recommended)
    poplar - I've used it. I had several pallets made of it and turned those into a guitar. A great place to start outside of pine. (Good for necks too)
    pine - The older the better but yes although soft and very susceptible to dents Pine can be a great choice, older the better. doug fir too.
    I'm in New England and that list is pretty much what I see a lot of up here with the exception of Red Elm, I see Northern Ash more. The only one I am surprised you don't have there on your list is maple which is plentiful here.
    You are on the right track. Good luck, remember to have fun!
  12. Ronkirn
    Jacksonville, FL
    leme just suggest.. if it's solid enough to hold the "stuff" in the correct relative positions, and "you" can play, it'll sound fine to the audience... If you don't like it.. no one in the audience cares...
    Now if ya don't play well.. the audience will let ya know . . so, don't forget to duck :D
    it's not the wood, it's the playin' . . :p
    rk
    John Nicholas and roffe like this.
  13. Casual_Reader
    Casual_Reader Tele-Holic
    Ohio
    or in the immortal words of Lee Trevino: "It's the Indian, not the arrow"
