Airline bias-vary tremolo isn't working
Discussion in 'Shock Brother's DIY Amps' started by DrewB, Aug 21, 2010.
  1. DrewB
    DrewB Tele-Afflicted
    Independence, MO
    I have a mid-'60s Airline GVC-9045A that uses the bias-vary tremolo circuit (separate 12AX7). I have the amp up and running, but the tremolo doesn't work. There is a single speed control (no intensity). What is the likely culprit and what's the best way to diagnose it? There is a schematic link here: http://www.tdpri.com/forum/amp-central-station/225574-airline-identification.html
    Thanks for your wisdom!
  2. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    Confirm that tube is good ? Swap the 12ax7s maybe...
  3. DrewB
    Independence, MO
    Yep, did that w/o any luck.
  4. TNO
    TNO Friend of Leo's
    NC-USA
    It's probably the caps. There should be three caps right together on the board. Possibly will all be the same value. Replace them with any decent cap of similar value and voltage rating.
