Airline 62-9015a - Schematic? Tips on Reverb/Tremolo?
Discussion in 'Amp Tech Center' started by mikestearns, Apr 7, 2020.
  1. mikestearns
    mikestearns Tele-Meister
    Hanover, PA
    I'm about to buy an Airline 62-9015a from a local shop, I haven't had a chance to play it yet but I know going into it that the reverb and tremolo don't work. I get those sounds from pedals, but I'd like to eventually repair them. Does anyone know where I can find a schematic? Are there specific things I should look for to be wrong with these circuits?
  2. Bendyha
    Bendyha Friend of Leo's Silver Supporter
    Northern Germany
    I think this is the same one, the GDR or 62 just refering to the retailer.
    D'tar likes this.
  3. mikestearns
    Hanover, PA
    The upload didn't come through, do you mind reposting? Thanks!
    Bendyha likes this.
  4. Bendyha
    Northern Germany
    Maybe this is better;
  5. Snfoilhat
    Snfoilhat Tele-Afflicted
    Oakland, CA
    That schematic isn't leaping out at me with familiarity and clarity, so take this only as a first-cup-of-coffee first impression, but it looks like both the reverb and the trem may be grounded at J5 when no plug is inserted.
  6. mikestearns
    Hanover, PA
    Thanks! Its enough for me to look at while I wait to have the money to pick it up.
  7. D'tar
    D'tar Friend of Leo's
    WNY
    Likely just missing the footswitch:)?
  8. Jon Snell
    Jon Snell Tele-Meister
    Jurassic Coast. UK.
    If there is no foot switch, by default both tremolo and reverb will be on.
    No reverb may be just a valve but possibly the tank. If it is the tank, a high impedance input tank is required as there is no transformer.
    I bet the valves are in the wrong sockets!
  9. mikestearns
    Hanover, PA
    I'm not sure, I haven't looked at it yet, the Reverb listing just said they didn't and that its most likely a nominal fix but the shop isn't equipped for it. (They do a lot of high end guitar repair and I'm sure don't want to dick around with this thing). I probably won't even concern myself that much with it unless I decide I don't like it and want to flip it.
  10. Jon Snell
    Jurassic Coast. UK.
    The other possibility of course is, if they are using a standard mono jack lead, (allot of unknowing people do), that will switch the reverb out as the pedal should have twin screened lead and a TRS connector.
    Not a bad deal though either way as worst case will be the tank, around $30 US or a new ECC82 $12 US even just a TRS lead at less.
    D'tar likes this.
  11. mikestearns
    Hanover, PA
    The shop ended up getting the trem to work. Channel A is pretty dirty sounding - it’s got some drive to it even at bedroom volumes. Does that seem normal on an amp like this? I feel like in 1965 amps wouldn’t have been made to overdrive, but it is also a budget amp.
