Air Compressor Reg.
Discussion in 'The DIY Tool Shed' started by SacDAve, Aug 26, 2019.
  1. SacDAve
    SacDAve Poster Extraordinaire Silver Supporter
    Rocklin Ca.
  2. RodeoTex
    Nueces Strip
    Is it a compressor that uses oil? If so I'd include an oil separater in the lineup.
  3. Bluey
    Bluey Tele-Meister
    Probably better off spending a few extra bucks & getting a good quality 3 stage coalescing filter/regulator setup. Contaminates through the system & redoing jobs will do your head in.
    Check when you drain the tank that its water only, no oil resedue. If some oil you may need to put a oil/ water trap @ the compressor & then the 3 stage at least 10' from the first oil/water trap. Then obviously run your gun hose from the 3 stage filter/reg.
    If moisture/ water only is still a problem a receiver dryer a couple of feet before the 3stage will fix it.
    The only problems you should have if any after this is your preperation & spraying environment.
    Milspec likes this.
  4. SacDAve
    Rocklin Ca.
    Good idea I'll check. Its old school
  5. SacDAve
    Rocklin Ca.
    Thanks. Right now I have filter regulator rated for food but can't figure out how to open it and clean the ceramic(?) filter in it. Job left over
  6. SacDAve
    Rocklin Ca.
    I put the old regulator back on for now Thinking about getting my filter separator serviced. It's a Excelon B73G-2AK-QT3 I can get a rebuild kit $46 but I can not figure out how to remove the bowl. I also notice the base gasket is leaking oil on my compressor so I have to get a new gasket for that.
