Affordable Dumble ODS clone from VHT is about to drop
Discussion in 'Amp Central Station' started by scout2112, Jan 9, 2020.
  1. scout2112
    scout2112 Tele-Holic
    Colorado, USA
    I took it (and other parts of this thread) to mean that the quality is only going to be as good as the individual components... “hand wired” is meaningless if the tolerances of the resistors and capacitors are all out of spec or wrong.
    Jared Purdy likes this.
  2. Jared Purdy
    Jared Purdy Friend of Leo's
    Toronto, Ontario.
    It struck me as another knee-jerk dump on hand wired amps. Of course not all hand wired amps are the same, but the vast majority of the well known ones out there, that are talked about frequently on this forum, will leave any PCB amp in the dust. His point was nothing but inflammatory and intentionally antagonistic.
  3. muchxs
    muchxs Doctor of Teleocity
    New England
    "The Inscrutable Black Box."
    It's like the three blind men and the elephant.
    I can assemble a kit of "OMG!" "Holy Grail" components, hand them off to a hack and I can think of a hack or two... and I'll end up with an amp that doesn't even work.
    Cheap resistors traditionally have been 20% tolerance. No tolerance band. That means they can be plus or minus 20%. In practice carbon composition resistors are generally high and they drift higher.
    Old Fender amps generally use resistors with 10% tolerance, silver band. In practice that means they start high and drift higher. 100k plate resistors drifted to 140k are pretty common. It doesn't matter in old Fenders for the most part. You can argue about it, you can point to the published values on the schematic. There are only a few parts in critical applications that need to be on spec.
    Most of yer modern crap is 5%, gold band. In practice they're close to spot on.
    From what I've seen of Dumble's work he measures everything measurable. That means he measures characteristics other builders wouldn't even think of measuring.
    As far as cloning goes...
    Uncle Howie was safe until the internet came along. A layer of silicone goop was enough to keep his secrets secret. With the internet we were able to establish neural nets of committed bootleggers to steal the keys to the Kingdom.
    Every Tom, Dick and Harry wandered in when we unlocked the door.
    Wally likes this.
  4. blowtorch
    Wisco
    I'll repeat and I'll try to be clearer ,for those with poor reading comprehension skills :): hand wiring, in and of itself, contributes nothing to the sound of the amp, for better or worse.
    stevemc and MilwMark like this.
  5. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    You're not wrong. Not at all.
    Silverface, stevemc and MilwMark like this.
  6. Jared Purdy
    Toronto, Ontario.
    When a reply goes into ad hominem assault mode, you know there's nothing to the argument. You've lost your point. Stay focused on the issue, instead of character assaults. And, you're wrong. And, you're another social media troll who's arrogant.
    David Barnett likes this.
  7. ping-ping-clicka
    ping-ping-clicka Tele-Afflicted Ad Free Member
    left coast
    remember the VHT Bulldog?
  8. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    I believe he's correct.
    I'm interested to hear why you think, all else being equal, pcb would sound any different than handwired assembly.
  9. Jared Purdy
    Toronto, Ontario.
    Empirical evidence suggests otherwise. That has been more than proven. The odd amp company, like Mesa, that uses very thick PCB boards, and the few others, are the exception.
  10. Askwhy
    Askwhy Tele-Meister
    Utah
    No onboard reverb is a deal killer for me. Wish they would add at least the digital like the fuchs casino series. But the speaker outs and ohm selector are the way every single amp head and combo should be, never could quite understand the hardwired jacks that necessitate an extra y-cable, (why-cable) for multiple speakers/cabs.
  11. blowtorch
    Wisco
    Me too :)
  12. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    So the thickness of the PCB, an insulator very often made of the same exact material (FR4) found in handwired turret board amps, affects sound? How?
    Where is the empirical evidence, you got a link?
  13. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    I don't think it is coming.
    Silverface, MilwMark and blowtorch like this.
  14. scout2112
    Colorado, USA
    I haven’t heard of that. Do you mean the pitbull they made back when they were still affiliated with Freyette?
  15. muchxs
    New England
    It has an FX loop. A near antique Yamaha reverb will give you more surf than a busload of old Fenders. Or a Quadraverb...
  16. Silverface
    Lawndale CA
    Yes - because the vast majority of boutique and custom amps happen to be hand wired - because it's just not practical to make one-off PCB's.
    But IMO you're missing the point - the "hand wiring" isn't what creates the sound. It's incidental and a matter of convenience. "Hand wiring" has no tone. Neither do PCB's. But specific components do.
    MilwMark, blowtorch and LuthRavin like this.
  17. Jared Purdy
    Toronto, Ontario.
    I thought that was clear enough. Of course the hand wiring itself is not the cause for better tone, it's the process of using better wire, not using cheap PCB (though some amp companies use thicker, higher quality PCB), better ways to mount tube sockets, etc. The "boutique" hand wired tube amps that are on the market, that are doing well, are using top shelf components, and that with the build process produces many amps that are better sounding (and more durable and more easily repaired) when compared to a similar amp that is mass produced with PCB and lesser components.
  18. Silverface
    Lawndale CA
    Agreed. You seemed to be implying it was the hand-wiring itself that was a major "sound" component. Thanks for clearing it up.
  19. Askwhy
    Askwhy Tele-Meister
    Utah
    True....with at least 2 more cables and another outlet. I like simple grab and go, you can still use anything you want in the loop if it is preferred.
  20. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    It wasn't. Claiming existence of empirical evidence is not the same as citing said evidence. Thanks for taking the time to elaborate.
    What is the best sounding wire?
    Which can be mounted on pcb just the same.
    What is the best sounding way to mount tube sockets?
    How is an amp similar if it's using lesser components?????
    Refute this: A mass-produced PCB amp sounds better compared to similar a handwired amp using lesser components.
