Advice: SF Champ vs PRRI
adjason
virginia
champ sounds overpriced- I may be in a minority but I sold my blackface champ-I far prefer the sound of almost any big boy fender amp even at low volume to the champ with 8 inch speaker (yes I had the champ serviced and it worked great)
Clickfiend
Seattle
I have both a SCX2 (w/ Celestion Greenback), and a PRRI ‘65 (w/ Celestion G12-65). I play both regularly and they def sound different (speaker/cabinet size maybe?). It’s also nice to have the different models in the SCX2. If you like clean with or without Reverb and Vibrato the PRRI with the 12” speaker is awesome even at low volume (and AMAZING at about 4). I don’t know about re-sale value on either amp mostly cuz I don’t see any reason other than complete unrepairable failure to get rid of them. I do have other amps, and Bias FX on my computer, but the PRRI and the SCX2 are all I really play. Hope you find the right thing for you :).
TwangerWannabe
West Coast
Thank you! I've been playing guitar for 35 years, but am not tech savvy at all. That's the information I was looking for! Leaning now towards holding off on the Champ and putting the $$ towards something PRRI-ish or nicer.
I have hyperacusis, so no gigs/bands for me anymore. Just playing at home and recording. But I'm such a clean tone fanatic, I think I'll be well served by saving up for something nicer. Thanks!
Princetons break uo pretty early on the dial, do if you're after a "clean" tone, the Princeton wouldn't be my first choice and since you have a SCX2 I really wouldnt go nuts about trying to find a PR or PRRI, but that's just my opinion.
Boreas
Adirondack Coast, NY
They are two very different beasts, both with some great points in their favor.
If you like to feel the thump, a PR will do that for you. The PR's onboard reverb and tremolo are very good and negate the need for reverb/trem pedals.
A Champ by itself will not thump--but it records huge if you stick a mic in front of the speaker. If you plug a Champ into a larger extension cab, it will rattle the windows. One way to help eradicate the boxy tone is to place it on the floor in the corner of the room about 12" from the walls with the speaker facing into the corner. It makes quite a positive difference.
I like to get mine off of the floor altogether. I sit it on my 68 PRRI. I also tilt the Princeton back a little to help define the tone a little.
985plowboy
South Louisiana
I have a SFVC.
It does what it does.
If I were in your shoes, I’d save my money and buy a version of the Princeton with a 12” speaker.
i think it’s more versatile.
If you get a silver face amp understand that you’re probably going to need to budget for it to be serviced.
Let us know how it turns out.
Boreas
With the hyperacusis, you may want to consider one of the new Fender Tonemasters. They supposedly deliver tube-like tone via a big-ass computer inside. But the reason I brought these to your attention is the 5-step power attenuator. You can dime the dials on the front and drop the power output down to as low as 0.2 Watts! Just a suggestion. Easy on the ears AND the back!
https://shop.fender.com/en-US/guita...tal/tone-master-deluxe-reverb/2274100000.html
Telecaster88
Midwest USA
Yes, thanks! I've thought of those, but it doesn't solve my worries about the digital end of the amp going bad and being impossible to repair, unless I'm missing something... The Tone Masters are digital, aren't they?
I have a Vox AV60, a model that went sadly under the radar and was consequently discontinued. It's a weird hybrid amp kind of like the SCX2, but the amp models are analog circuits. The built in effects are digital. That amp has a master volume and it's a godsend for me! Great tone at low volume.
This whole thread is simply prompted by my worry that my SCX2 is gonna kick the bucket one day with no chance at resuscitation.
hepular
abilene, tx
if your worry is maintenance, planned-obsolescence, the answer is champ. Have you seen the inside of an RI? unless you buy the high$$ handwired, you get weird looking input jack destined to fail and be hard to repair, a heaping chunk of pcbs which might or might not be frying cuz of the tube sockets (i forget, did they fix those) & filter caps that might or might not've been specced out of the back of a truck somewhere, not to mention the questionable transformers. whereas with a champ . . . you might have to replace the cap can and some other electrolytics.
Boreas
I forgot about the fix-ability part. Yes, they are digital. I have not seen a gut shot, but some digital amps have modular components/sections that you would swap out rather than repair. I do not know if this is the case with the Tonemasters.
Frankly, I only see amps like the SCX2 and AV60 getting better with every new iteration. Still difficult to fix, though. They are meant to be disposable. If your SCX2 craps out, you should be able to find another one, even if they are eventually discontinued. They are a nice amp and plenty have been made. I would imagine used ones are quite affordable. If you really like the amp, then you need to look no further. There are some nice limited editions out there now. My advice is to stay with the one you have and if it dies, cross that bridge when you come to it. The amp may outlive YOU for all you know - especially since you are not beating on it. Take that $600 and buy a nice Squier Tele instead!!
100LL
Houston, TX
Well if you have trouble down the road with a PRRI or similar non-handwired reissue there are several good choices (ordered here from most to least expensive):
  1. Send the chassis off to a place like Allesandro for a hand-wire overall (totally new electricronics, including pots, connectors and of course a hand-wiring of all the components). http://alessandro-products.com/rewiring-services/
  2. Buy a kit from Mojotone or similar, and do all that yourself. https://www.mojotone.com/kits/Black...e-Blackface-Princeton-Reverb-Style-Head-Kit_2
  3. Buy one of the PCBs on eBay or similar. Many are available from guys like alessandro that pull new ones for their "vintage continuation" offerings. They basically buy new PRRIs, pull the electronics (and sell them) so they can do their hand-wired work.
Telecaster88
Midwest USA
Frankly, I only see amps like the Why spend money if you don't have to?SCX2 and AV60 getting better with every new iteration. Still difficult to fix, though. They are meant to be disposable. If your SCX2 craps out, you should be able to find another one, even if they are eventually discontinued. They are a nice amp and plenty have been made. I would imagine used ones are quite affordable. If you really like the amp, then you need to look no further. There are some nice limited editions out there now. My advice is to stay with the one you have and if it dies, cross that bridge when you come to it. The amp may outlive YOU for all you know - especially since you are not beating on it. Take that $600 and buy a nice Squier Tele instead!!
Yes, now that I'm calming down I'm realizing this is all a solution in search of a problem... My SCX2 currently works and sounds great, and maybe it'll outlast me. I have other amps on hand already I like too. My GAS started just because I always keep an eye out for clean Champs for sale locally, and this one popped up. I really don't need another amp right now, so I should just chill out!
Thanks to this thread I think I've learned that if/when it's time for a new amp, the PRRI will likely fill all my needs. I appreciate all your advice!
pi
bay area, CA
I've heard the channel 1 of SCX2 is very similar to a Princeton. If you buy it now you'll basically have a less versatile version of what you already have. I would just keep it and be happy.
Save the money, and if the SCX2 dies, then you can get the Princeton.
Telecaster88
Midwest USA
Sage advice, and I think that's just what I'm gonna do! Thanks, everyone!
Boreas
Glad to hear you are sorting this all out. It isn't a bad idea to continue keep an eye out for a good Vibro Champ or other vintage amp, not as a replacement for what you have, but rather as an investment or just dipping your toe into the vintage world. They also offer an opportunity to learn how to service old tube amps by watching Uncle Doug videos on YouTube! It can become quite a hobby in itself with a few tools and some acquired knowledge. I had a lot of fun recapping my VC - even though the original caps from 1969 were working fine. Old Silvertone tube amps are often found for peanuts, and can sound damn near as good as a Fender. But prices are going up on those as well, so keep your eyes open - reviving old gear can be quite an enjoyable hobby!!
Telecaster88
Midwest USA
I'm not technical, but I can follow directions and sometimes I'm not so dumb... Ha. I think it would be really rewarding to learn that stuff on a simple old amp. Maybe that will be part of my retirement plans!
I scoped out the mojotone amp kits @100LL posted above and saw you could build a Princeton Reverb clone in 5 hours! That's inspiring.
Boreas
Building is pretty easy - especially with good instructions. Some sellers of kits allow you to download the instructions before you buy. I have looked at a few and most are pretty good. The main thing is if the instructions are unclear or beyond your abilities, don't buy the kit! No one wants a $600 brick. But it isn't rocket science and as long as you are GOOD at soldering and able to dial the company's help number, you should be all set.
Troubleshooting old gear requires more knowledge and time. Yes, vintage gear can usually be fixed, but the labor costs to diagnose can spoil the fun. Most repairs start with replacing all old caps for stability down the road. Then troubleshooting tubes and biasing. Then testing transformers and resistors. It all depends on how thorough your tech is.
That being said, many vintage amps play just fine for 50+ years without requiring any repairs. But it would be risky to use them gigging because old caps can die in an instant and leave you stranded. Not an issue in the living room. So vintage guitars and amps are similar to vintage cars. The more you can learn to fix yourself, the happier you will be. Stay safe. Remember to keep one hand in your pocket when inside an amp!
New Posts
