I needed a project, so appropriately I bought a little Sound Projects Co/Lectrolab/maybe Harmony also? R100B. I'll post before and after pics later; I have the tubes, 3 prong cable, knob and some other stuff on order, so for now I'm looking for some advice on a few power and safety related things.
I couldn't find a schematic for it, but someone did one for a Model 203 and the power section is exactly the same. Note it it does have a PT, but the heaters are run in series directly off the AC line. I will remove the death cap.
So my questions are:
1. Should I install a fuse? I ordered a fuse holder, but I only have 0.5A and 2A fuses. If I put a fuse in, what value should I use?
2. For the new power cable, should I wire line and neutral as shown with the (fuse) and switch on line, or wire like my 5F1 with the switch on neutral (and fuse on line)?
3. If my calculations are correct, given modern 120VAC line voltage that 130 Ohm resistor will be dissipating a little over 4 Watts. Should I beef it up in terms of power handling?
(It may be that this thing could be modified to do away with that resistor. There is an unused secondary tap, but of course until I get power to it, I won't know what the voltage on it is. However, since I'm not expecting this thing to sound good, I'm probably not going to want to go to that length to mod it).
Any and all help appreciated. Thanks!
