Advantages of an FX loop?
Discussion in 'Modeling Amps, Plugins and Apps' started by dobrojoe, Jun 8, 2018.
  1. dobrojoe
    dobrojoe Tele-Meister
    England
    I've just bought a Katana 100 and a Helix HX. What is the difference between using the FX in the amp's FX loop and plugging it straight into the input?
  2. Togman
    Togman Tele-Afflicted Silver Supporter
    Cambridgeshire, UK
    I can't speak for the Katana, but I find that when I use delay in the effects loop on my Hughes & Kettner amp I get a much fuller/fatter sound to the delay.
  3. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    If you use the amps overdrive, your boost for solos won’t do anything in from if the amp except make it more overdriven. If you put a boost in the loop, you get the desired effect.
  4. rickthescot
    rickthescot Tele-Afflicted
    We could talk for hours about the technical aspects of the loop, but forget all that for now and just plug your effects in both ways for a while. You'll soon figure out what is going on. Some don't see the benefit but I for one use my effects loop all the time.
    It is very helpful with a looper as well allowing you to change tone for each loop you create.
  5. Frodebro
    Seattle
    If you hook up your Helix to the Katana using the four cable method (4CM), you can select between the amp modeling from each unit using just the presets on the Helix.
    Guitar>Helix input
    Helix loop send>Katana input
    Katana loop send>Helix loop return
    Helix main out>Katana loop return
    This also allows you to run the wah, compressor, and drives in the Helix in front of the Katana preamp, with the modulation, delays, and reverb after it.
    Very versatile setup once the initial programming is done.
  6. Blrfl
    Blrfl Tele-Afflicted
    Northern Virginia
    Most amps put the effects loop after the preamp, which puts anything you add before any built-in effects and the power amp. The advantage is that it gets you a line-level (+4 dBu, or decibels referenced to 0.775 volts) signal suitable for processors designed for that. Think rack-mount units not specifically designed to be used with guitars: equalizers, compressors, reverbs, etc.
    If you put those processors in line between the guitar and the preamp, they're going to be fed an instrument-level signal, which is nominally -20 dBu. To give you some idea of the difference, each change of 3 dB in the negative direction halves the amount of energy involved, so the -24 dB difference results in the processor getting less than 0.5% of the signal it wants. That's like turning your guitar waaaaay down and trying to make up for it by cranking up the amp. It isn't going to sound good because any noise in the processor is going to get amplified and it isn't going to sound good.
    I could probably write a few pages on this, but the bottom line is that you need to read the spec sheet for your effects and see where they'll work. Line-level belongs in the effects loop; instrument-level belongs before the amplifier's input. Many (but not all) stomp boxes can tolerate either, so you have some room to experiment.
    --Mark
    P.S.: The Helix is an unusual case because it's got a whole lot of inputs and outputs that are designed to deal with different configurations.
    Cliffyg62 likes this.
